Samsung Galaxy A20e Display Replacement
    1. Samsung Galaxy A20e Display Replacement, Display: step 1, image 1 of 2 Samsung Galaxy A20e Display Replacement, Display: step 1, image 2 of 2
      • Remove the SIM and MicroSD tray.
      Ask FixBot
    2. Samsung Galaxy A20e Display Replacement: step 2, image 1 of 2 Samsung Galaxy A20e Display Replacement: step 2, image 2 of 2
      • Release the back cover with the help of a thin blade or a Jimmy. Insert the tool between the frame display and the cover unclipping it along the entire perimeter.
      • Insert a Jimmy between the display frame and the side shell and slide it along the edge, in order to completely disengage the two parts.
      • Be careful if you use a Jimmy as they are made of metal and make breaking internal components very easy. It is preferable to use a plastic utensil.
      Ask FixBot
    3. Samsung Galaxy A20e Display Replacement: step 3, image 1 of 1
      • Disconnect the Fingerprint scanner.
      Ask FixBot
    4. Samsung Galaxy A20e Display Replacement: step 4, image 1 of 1
      • Using a Philips #00 screwdriver, remove the 13 screws securing the inner cover.
      Ask FixBot
    5. Samsung Galaxy A20e Display Replacement: step 5, image 1 of 3 Samsung Galaxy A20e Display Replacement: step 5, image 2 of 3 Samsung Galaxy A20e Display Replacement: step 5, image 3 of 3
      • Now you can remove the upper and lower covers that protect the logic board and the speaker respectively.
      Ask FixBot
    6. Samsung Galaxy A20e Display Replacement: step 6, image 1 of 2 Samsung Galaxy A20e Display Replacement: step 6, image 2 of 2
      • Pry up the following four connectors:
      • Battery connector;
      • Display connector;
      • Power / volume buttons;
      • Lower logic board connector.
      • The lower logic board ribbon cable must be disconnected from the lower board as well before proceeding with the next steps.
      • There is an arrow on the ribbon cable connecting the lower board with the logic board. When reinstalling it, this arrow must point towards the main board.
      Ask FixBot
    7. Samsung Galaxy A20e Display Replacement, Remove The Battery: step 7, image 1 of 1
      • Remove the battery by placing a few drops of alcohol underneath the battery and letting it sit for about a minute. This will weaken the double-sided adhesive that holds the battery.
      • If you notice that it wasn't enough, and you need to use too much force, with the risk of bending or damaging the battery, apply more alcohol.
      • Never puncture or bend the battery.
      • During reassembly, remember to apply new double-sided tape to hold the battery in place.
      Ask FixBot
    8. Samsung Galaxy A20e Display Replacement: step 8, image 1 of 3 Samsung Galaxy A20e Display Replacement: step 8, image 2 of 3 Samsung Galaxy A20e Display Replacement: step 8, image 3 of 3
      • Disconnect the two blue and white antenna wires.
      • Remember the locations of these wires when you reassemble the phone.
      • Remove the motherboard by lifting it away by the upper part.
      • Carefully remove the microphone, as it is glued and easily damaged. Try to warm up that area a little to make it easier.
      Ask FixBot
    9. Samsung Galaxy A20e Display Replacement: step 9, image 1 of 3 Samsung Galaxy A20e Display Replacement: step 9, image 2 of 3 Samsung Galaxy A20e Display Replacement: step 9, image 3 of 3
      • Remove the glued-on vibration motor with the help of a small amount of heat
      • Remove the lower motherboard.
      • Remove the glued-on speaker with the help of a heat source.
      Ask FixBot
    10. Samsung Galaxy A20e Display Replacement: step 10, image 1 of 3 Samsung Galaxy A20e Display Replacement: step 10, image 2 of 3 Samsung Galaxy A20e Display Replacement: step 10, image 3 of 3
      • Once you have completed the component removal, you can begin the reassembly by placing the components on the new display.
      Ask FixBot
22 other people completed this guide.
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Smilzo
12,380 Reputation
39 Guides authored
14 Guide Comments
this guide isn’t for a A20 its for an A20e
CPR Jackson TN - Reply Share
Ciao,il codice completo è A20E SM-A202f .
se cerchi questo codice nelle guide riparazione trovi telefono-Android-Samsung-A- A20e SM-A202f trovi la mia guida del display. Non posso nominarla come la cartella genitore,non so se questo è un bug. Grazie
Smilzo - Reply Share
If you're gonna re-use the battery I wouldn't use heat, it damages the cells inside of the battery. Just pry with a spudger and have
Joey van Beek - Reply Share
I'm sorry I don't agree with a spudger without adequate heat the battery would bend to be removed. The adhesive is very resistant and the heat must be dosed appropriately for the situation so as not to damage the battery and the other components
@joeyhelmond0492: That is not the whole truth. And prying it with a spudger just like that is a recipe for breaking it.
The ideal solution is a heated gel pad, but from the display side, while the battery sits on a cool gel pad or heat spreader (from a PC cooler) and only letting the glue come up to 60° before removing the gel pads and removing the battery.
Electronics are wave soldered nowadays anyway, which is literally a wave of molten metal, which is way hotter than 60°C. So they are designed to take that for a short time. The battery is not, but can handle 60°C for a bit too. The only problem is hot spots that cause uneven expansion, which is the same as bending it. Hence 1. using a gel pad, and 2. making sure the heat goes through the display, not through the battery.
(Note: Quick cooling is just as bad as quick heating.)
Evi1M4chine - Reply Share
Past 24 Hours: 5
Past 7 Days: 42
Past 30 Days: 218
All Time: 30,913
