Samsung Galaxy A15 Back Cover Replacement
    1. Samsung Galaxy A15 Back Cover Replacement, Prepare the phone for disassembly: step 1, image 1 of 3 Samsung Galaxy A15 Back Cover Replacement, Prepare the phone for disassembly: step 1, image 2 of 3 Samsung Galaxy A15 Back Cover Replacement, Prepare the phone for disassembly: step 1, image 3 of 3
      • Let the phone's battery drain below 25% before starting this repair. A charged lithium-ion battery may catch fire if damaged.
      • Unplug all cables and completely power off the phone.
      • Press and hold the power and volume down buttons at the same time to bring up the shutdown menu.
      Ask FixBot
    2. Samsung Galaxy A15 Back Cover Replacement, Heat the right edge: step 2, image 1 of 1
      • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
      • A hair dryer may also be used, but be careful not to overheat the phone—the display, internal battery, and plastic back are susceptible to heat damage. The phone should be just too hot to touch comfortably.
      Ask FixBot
    3. Samsung Galaxy A15 Back Cover Replacement: step 3, image 1 of 1
      • While you're waiting for the adhesive to soften, here is some useful information:
      • There's adhesive securing the back cover around the perimeter of the frame.
      • There is an additional layer of adhesive towards the bottom of the phone. Apart from this area, you should not be deeper than 4 mm from the edge.
      Ask FixBot
    4. Samsung Galaxy A15 Back Cover Replacement, Insert an opening pick: step 4, image 1 of 3 Samsung Galaxy A15 Back Cover Replacement, Insert an opening pick: step 4, image 2 of 3 Samsung Galaxy A15 Back Cover Replacement, Insert an opening pick: step 4, image 3 of 3
      • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
      • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
      • If you have trouble, apply more heat to further soften the adhesive.
      • Insert an opening pick into the gap.
      Ask FixBot
    5. Samsung Galaxy A15 Back Cover Replacement, Slice the adhesive: step 5, image 1 of 3 Samsung Galaxy A15 Back Cover Replacement, Slice the adhesive: step 5, image 2 of 3 Samsung Galaxy A15 Back Cover Replacement, Slice the adhesive: step 5, image 3 of 3
      • Slide the opening pick along the right edge between the back cover and the frame to slice through the adhesive.
      • Leave the opening pick in the bottom right corner to keep the adhesive from resealing.
      Ask FixBot
    6. Samsung Galaxy A15 Back Cover Replacement: step 6, image 1 of 1
      • Reheat your iOpener and apply it to the bottom of the back cover for two minutes.
      Ask FixBot
    7. Samsung Galaxy A15 Back Cover Replacement: step 7, image 1 of 3 Samsung Galaxy A15 Back Cover Replacement: step 7, image 2 of 3 Samsung Galaxy A15 Back Cover Replacement: step 7, image 3 of 3
      • Insert another opening pick in the bottom right corner and slide it along the bottom edge to slice through the adhesive.
      • Leave this opening pick in the bottom left edge to prevent the adhesive from resealing.
      Ask FixBot
    8. Samsung Galaxy A15 Back Cover Replacement: step 8, image 1 of 1
      • Reheat your iOpener and apply it to the left side of the back cover for two minutes.
      Ask FixBot
    9. Samsung Galaxy A15 Back Cover Replacement: step 9, image 1 of 3 Samsung Galaxy A15 Back Cover Replacement: step 9, image 2 of 3 Samsung Galaxy A15 Back Cover Replacement: step 9, image 3 of 3
      • Insert another opening pick in the bottom left corner and slide it along the left edge to slice through the adhesive.
      • Leave this opening pick in the top left corner to prevent the adhesive from resealing.
      • Only insert the pick up to 4 mm deep to avoid damaging the rear cameras or flash.
      Ask FixBot
    10. Samsung Galaxy A15 Back Cover Replacement: step 10, image 1 of 1
      • Reheat your iOpener and apply it to the top of the back cover for two minutes.
      Ask FixBot
    11. Samsung Galaxy A15 Back Cover Replacement: step 11, image 1 of 2 Samsung Galaxy A15 Back Cover Replacement: step 11, image 2 of 2
      • Insert another opening pick in the top left corner at the same depth and slide it along the top edge to slice through the adhesive.
      • Leave this opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    12. Samsung Galaxy A15 Back Cover Replacement, Unfasten the camera clips: step 12, image 1 of 3 Samsung Galaxy A15 Back Cover Replacement, Unfasten the camera clips: step 12, image 2 of 3 Samsung Galaxy A15 Back Cover Replacement, Unfasten the camera clips: step 12, image 3 of 3
      • Insert an opening pick along the top edge of the phone and twist it gently to unfasten the camera clips.
      • Slide the opening pick around the edge of the camera modules to unfasten the remaining camera clips.
      • Only insert the pick up to 4 mm to avoid damaging the rear cameras or flash.
      Ask FixBot
    13. Samsung Galaxy A15 Back Cover Replacement, Slice remaining adhesive: step 13, image 1 of 3 Samsung Galaxy A15 Back Cover Replacement, Slice remaining adhesive: step 13, image 2 of 3 Samsung Galaxy A15 Back Cover Replacement, Slice remaining adhesive: step 13, image 3 of 3
      • Once the adhesive around the edges is loose, insert an opening pick deeper into the bottom edge from the bottom left corner.
      • Slide the pick deeper into the phone across the bottom edge, slicing the remaining adhesive.
      Ask FixBot
    14. Samsung Galaxy A15 Back Cover Replacement, Remove the back cover: step 14, image 1 of 3 Samsung Galaxy A15 Back Cover Replacement, Remove the back cover: step 14, image 2 of 3 Samsung Galaxy A15 Back Cover Replacement, Remove the back cover: step 14, image 3 of 3
      • Lift and remove the back cover.
      • During reassembly:
      • This is a good point to power on the phone and test all functions before sealing it up. Be sure to power the phone back down completely before you continue working.
      • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat and isopropyl alcohol (90% or greater) if you're having trouble removing the adhesive.
      • If you're using custom-cut adhesives, follow this guide.
      • If you're using double-sided tape, follow this guide.
      Ask FixBot
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
16 other people completed this guide.
Carsten Frauenheim
171,572 Reputation
441 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,737 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 77
Past 30 Days: 384
All Time: 10,659
