Samsung Galaxy A12 Disassembly
    1. Samsung Galaxy A12 Disassembly, Housing: step 1, image 1 of 1
      • Remove sim tray first
      Ask FixBot
    2. Samsung Galaxy A12 Disassembly, Take off the back: step 2, image 1 of 2 Samsung Galaxy A12 Disassembly, Take off the back: step 2, image 2 of 2
      • Pop off the plastic back
      • Disconnect the lock button flex
      Ask FixBot
    3. Samsung Galaxy A12 Disassembly, Unscrew the plastic covers: step 3, image 1 of 2 Samsung Galaxy A12 Disassembly, Unscrew the plastic covers: step 3, image 2 of 2
      • Take the screws out
      • They're all the same size
      Ask FixBot
    4. Samsung Galaxy A12 Disassembly, Remove plastic covers: step 4, image 1 of 1
      • Remove plastic covers
      Ask FixBot
    5. Samsung Galaxy A12 Disassembly, Detaching main board: step 5, image 1 of 3 Samsung Galaxy A12 Disassembly, Detaching main board: step 5, image 2 of 3 Samsung Galaxy A12 Disassembly, Detaching main board: step 5, image 3 of 3
      • Unclip flex cables, starting with smaller
      • Unwind grounding screw
      • Disconnect antenna
      • Pop off the main board from Sim tray slot with spudger
      Ask FixBot
    6. Samsung Galaxy A12 Disassembly, Detach sub board: step 6, image 1 of 1
      • Pop the flex off
      • Lift board with ease, kindly minding the adhesive
      Ask FixBot
    7. Samsung Galaxy A12 Disassembly, Battery: step 7, image 1 of 3 Samsung Galaxy A12 Disassembly, Battery: step 7, image 2 of 3 Samsung Galaxy A12 Disassembly, Battery: step 7, image 3 of 3
      • Put flex cable out of the way
      • Credit-card size plastic tool
      • Wedge between the side of the battery down to the corner and apply isopropyl alcohol
      • Tilt camera end up to avoid leaking into battery
      • Pry up the battery being careful to not damage it
      Ask FixBot
To reassemble your device, follow these instructions in reverse order, being sure to reattach any and every piece.
93 other people completed this guide.
username
2,205 Reputation
1 Guide authored
7 Guide Comments
The volume of my phone is down when receiving a call
zani gift shabangu - Reply Share
Thanks for this. Phone successfully fixed! Just an additional note for people, I noticed my replacement part was missing a lot of the grey gaskets. There are a few of these under both boards, a few small square ones, and a very thin windy one under the bottom board. Not sure if required but I transferred these across to my new one using some tweezers to very carefully peel them off. Make sure you get the "glue" bit underneath to come up at the same time if you can, otherwise you may need extra glue to reattach them. Be careful transferring the volume buttons too, they need to be carefully taken off in the same way and reattached to the new one.
KevinG - Reply Share
How can i reset my PIN that I had forgotten without a hard reset on my A12?
Rudaina Mustafa - Reply Share
يمكن تخطى القفل باستخدام اللابتوب
moga2 - Reply Share
Very good thing you are doing here Big up's
Charles Aboraa - Reply Share
Past 24 Hours: 30
Past 7 Days: 182
Past 30 Days: 765
All Time: 50,131
