Samsung Galaxy A12 Battery Replacement
    1. Samsung Galaxy A12 Battery Replacement, Battery: step 1, image 1 of 1
      • Turn off the smartphone
      • Place your smartphone on a safe surface
      Ask FixBot
    2. Samsung Galaxy A12 Battery Replacement: step 2, image 1 of 2 Samsung Galaxy A12 Battery Replacement: step 2, image 2 of 2
      • Use the iFixit Opening Picks to pry open the plastic back of the smartphone.
      • **Be careful of pulling too hard the fingerprint sensor cable is connected to the plastic back** (see second picture)
      Ask FixBot
    3. Samsung Galaxy A12 Battery Replacement: step 3, image 1 of 1
      • Remove the covers with the screwdriver.
      • **Be careful with touching anything with the screwdriver in the motherboard**
      Ask FixBot
    4. Samsung Galaxy A12 Battery Replacement: step 4, image 1 of 1
      • Now that we have the covers removed the phone back should look like this
      Ask FixBot
      • Before continuing we need to remove the fingerprint sensor.
      • While you can use the Spudger. I used the iFixit Opening Tool for this video example.
      Ask FixBot
      • Use the Spudger to detach the main board cable gently
      • Move to the battery cable
      • **Both cables are crucial for the smartphone to be operational treat gently **
      Ask FixBot
32 other people completed this guide.
Osvaldo Rodriguez
1,274 Reputation
1 Guide authored
3 Guide Comments
SAMSUNG A 12
1) opening the case is a challenge.
Remove the sim card with pin after you power off the phone!
After some prying with a pocket knife ( found bottom left corner , viewed from the phone front ...->was able to partial separate the case. With a helper, they inserted the stick pry tool in the crack and the with continuous inward pressure slide tool up along the crack to the top of phone. Back to pocket knife 2x- 3x more times to release additional aspects of case.
2)The videos are very useful.
3) The battery on my phone was held in with 2way tape. I used two coins,suggest dimes to pry battery bottom* (*opposite end of small battery connector) Then using picks on the sides as it very gradully opens up. I took me at close to a min. to gradually pry it out.
4)
I used a couple small peice of 2way tape on the new battery prior to installing it.
I owned a consumer electronics store and did a variety of electronics repairs.
Thought these details would be helpful.
Dennis - Reply Share
Stick pry tool should have said pick pry tool.
Dennis
لويش البطاريه تصرف شحن
Ahmad Amaireh - Reply Share
Past 24 Hours: 14
Past 7 Days: 115
Past 30 Days: 536
All Time: 16,613
