Introduction
A smartphone motherboard houses various critical components of your device, including the storage, processor, camera, and more. If your device is not turning on, the screen is malfunctioning, frequently restarts, or overheating with minimal heat, follow this guide to safely remove or replace the motherboard in your Samsung Galaxy A11.
For your safety, this guide lists how to remove the battery from your device prior to removing the motherboard. Follow these instructions to tell if your battery is swollen, to remove and recycle it, to prevent future swollen batteries.
If you are replacing the motherboard in your phone, and are therefore disposing of your old motherboard, follow these instructions.
Place the SIM eject tool in the hole of the sim tray.
Push until part of the SIM tray is pushed out.
Pull out the rest of the SIM tray.
Remove the three 3 mm screws from the shield using a Phillips #000 screwdriver.
Remove the shield from the phone.
Using a spudger, detach the ribbon cable connected to the fingerprint sensor.
Remove the fingerprint sensor from the device.
Remove the two 3 mm silver screws from the top left of the device using a Phillips #000 screwdriver.
2 other people completed this guide.
