Samsung Galaxy A11 Front Facing Camera Replacement
    1. Samsung Galaxy A11 Front Facing Camera Replacement, Back Cover: step 1, image 1 of 3 Samsung Galaxy A11 Front Facing Camera Replacement, Back Cover: step 1, image 2 of 3 Samsung Galaxy A11 Front Facing Camera Replacement, Back Cover: step 1, image 3 of 3
      • Place the SIM eject tool in the hole of the sim tray.
      • Push until part of the SIM tray is pushed out.
      • Pull out the rest of the SIM tray.
      Ask FixBot
    2. Samsung Galaxy A11 Front Facing Camera Replacement: step 2, image 1 of 3 Samsung Galaxy A11 Front Facing Camera Replacement: step 2, image 2 of 3 Samsung Galaxy A11 Front Facing Camera Replacement: step 2, image 3 of 3
      • Gently pry open the area of the back cover near the SIM tray using an iFixit opening pick.
      • Gently move the pick along the gap and pry open the clips holding it together.
      • If possible, use multiple picks to prevent the back cover from closing.
      Ask FixBot
    3. Samsung Galaxy A11 Front Facing Camera Replacement: step 3, image 1 of 3 Samsung Galaxy A11 Front Facing Camera Replacement: step 3, image 2 of 3 Samsung Galaxy A11 Front Facing Camera Replacement: step 3, image 3 of 3
      • Using a hair dryer on low heat, heat the fingerprint sensor in increments of 30 seconds to loosen the surrounding adhesive.
      • Gently push the fingerprint sensor until it detaches from the back cover.
      • If needed, remove the button by prying it from the bottom of the device.
      Ask FixBot
    1. Samsung Galaxy A11 Front Facing Camera Replacement, Battery: step 4, image 1 of 3 Samsung Galaxy A11 Front Facing Camera Replacement, Battery: step 4, image 2 of 3 Samsung Galaxy A11 Front Facing Camera Replacement, Battery: step 4, image 3 of 3
      • Remove the three 3 mm screws from the shield using a Phillips #000 screwdriver.
      • Remove the shield from the phone.
      Ask FixBot
    2. Samsung Galaxy A11 Front Facing Camera Replacement: step 5, image 1 of 3 Samsung Galaxy A11 Front Facing Camera Replacement: step 5, image 2 of 3 Samsung Galaxy A11 Front Facing Camera Replacement: step 5, image 3 of 3
      • Using tweezers, a spudger, or your fingers, disconnect the battery press connector from the phone.
      Ask FixBot
    3. Samsung Galaxy A11 Front Facing Camera Replacement: step 6, image 1 of 3 Samsung Galaxy A11 Front Facing Camera Replacement: step 6, image 2 of 3 Samsung Galaxy A11 Front Facing Camera Replacement: step 6, image 3 of 3
      • If needed, use a hairdryer on low heat to soften the adhesive under the battery. If The Battery Is Expanded, DO NOT USE A HAIRDRYER or heat; be very careful when removing to not puncture the battery.
      • Use an iFixit pry tool to dig under the battery edge.
      • If needed, use multiple pry tools to hold the battery in place.
      • Continue to cut the adhesive under the battery until you are able to pry the battery away from the phone.
      • Remove the battery from the phone.
      Ask FixBot
    1. Samsung Galaxy A11 Front Facing Camera Replacement, Fingerprint Sensor: step 7, image 1 of 3 Samsung Galaxy A11 Front Facing Camera Replacement, Fingerprint Sensor: step 7, image 2 of 3 Samsung Galaxy A11 Front Facing Camera Replacement, Fingerprint Sensor: step 7, image 3 of 3
      • Using a spudger, detach the ribbon cable connected to the fingerprint sensor.
      • Remove the fingerprint sensor from the device.
      Ask FixBot
    1. Samsung Galaxy A11 Front Facing Camera Replacement, Motherboard: step 8, image 1 of 1
      • Remove the two 3 mm silver screws from the top left of the device using a Phillips #000 screwdriver.
      Ask FixBot
    2. Samsung Galaxy A11 Front Facing Camera Replacement: step 9, image 1 of 3 Samsung Galaxy A11 Front Facing Camera Replacement: step 9, image 2 of 3 Samsung Galaxy A11 Front Facing Camera Replacement: step 9, image 3 of 3
      • Using a spudger, disconnect the two ribbon cables attached to the battery slot from the motherboard.
      • Disconnect the two longer ribbon cables near the bottom right corner of the motherboard.
      • Lift these cables up slightly to reveal a gap.
      Ask FixBot
    3. Samsung Galaxy A11 Front Facing Camera Replacement: step 10, image 1 of 3 Samsung Galaxy A11 Front Facing Camera Replacement: step 10, image 2 of 3 Samsung Galaxy A11 Front Facing Camera Replacement: step 10, image 3 of 3
      • Using a spudger, gently pry the motherboard up using the corner revealed in the previous step.
      • If needed, use a metal spudger as a sturdier alternative.
      • If using a metal spudger, it is important to be gentle in order to not damage any components of the device.
      • Remove the motherboard from the device.
      Ask FixBot
    1. Samsung Galaxy A11 Front Facing Camera Replacement, Front Facing Camera: step 11, image 1 of 3 Samsung Galaxy A11 Front Facing Camera Replacement, Front Facing Camera: step 11, image 2 of 3 Samsung Galaxy A11 Front Facing Camera Replacement, Front Facing Camera: step 11, image 3 of 3
      • Gently use tweezers to peel up the copper strip that spans from the front facing camera to the motherboard.
      • If you are using metal tweezers, be gentle in order to avoid damaging the device.
      Ask FixBot
    2. Samsung Galaxy A11 Front Facing Camera Replacement: step 12, image 1 of 3 Samsung Galaxy A11 Front Facing Camera Replacement: step 12, image 2 of 3 Samsung Galaxy A11 Front Facing Camera Replacement: step 12, image 3 of 3
      • Flip the motherboard over.
      • Using a spudger, disconnect the front facing camera from the motherboard.
      Ask FixBot
Alec Searle
252 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 40
All Time: 566
