Samsung Galaxy A11 Daughterboard Replacement
  1. Samsung Galaxy A11 Daughterboard Replacement, Back Cover: step 1, image 1 of 3 Samsung Galaxy A11 Daughterboard Replacement, Back Cover: step 1, image 2 of 3 Samsung Galaxy A11 Daughterboard Replacement, Back Cover: step 1, image 3 of 3
    • Place the SIM eject tool in the hole of the sim tray.
    • Push until part of the SIM tray is pushed out.
    • Pull out the rest of the SIM tray.
  2. Samsung Galaxy A11 Daughterboard Replacement: step 2, image 1 of 3 Samsung Galaxy A11 Daughterboard Replacement: step 2, image 2 of 3 Samsung Galaxy A11 Daughterboard Replacement: step 2, image 3 of 3
    • Gently pry open the area of the back cover near the SIM tray using an iFixit opening pick.
    • Gently move the pick along the gap and pry open the clips holding it together.
    • If possible, use multiple picks to prevent the back cover from closing.
  3. Samsung Galaxy A11 Daughterboard Replacement: step 3, image 1 of 3 Samsung Galaxy A11 Daughterboard Replacement: step 3, image 2 of 3 Samsung Galaxy A11 Daughterboard Replacement: step 3, image 3 of 3
    • Using a hair dryer on low heat, heat the fingerprint sensor in increments of 30 seconds to loosen the surrounding adhesive.
    • Gently push the fingerprint sensor until it detaches from the back cover.
    • If needed, remove the button by prying it from the bottom of the device.
  4. Samsung Galaxy A11 Daughterboard Replacement, Battery: step 4, image 1 of 3 Samsung Galaxy A11 Daughterboard Replacement, Battery: step 4, image 2 of 3 Samsung Galaxy A11 Daughterboard Replacement, Battery: step 4, image 3 of 3
    • Remove the three 3 mm screws from the shield using a Phillips #000 screwdriver.
    • Remove the shield from the phone.
  5. Samsung Galaxy A11 Daughterboard Replacement: step 5, image 1 of 3 Samsung Galaxy A11 Daughterboard Replacement: step 5, image 2 of 3 Samsung Galaxy A11 Daughterboard Replacement: step 5, image 3 of 3
    • Using tweezers, a spudger, or your fingers, disconnect the battery press connector from the phone.
  6. Samsung Galaxy A11 Daughterboard Replacement: step 6, image 1 of 3 Samsung Galaxy A11 Daughterboard Replacement: step 6, image 2 of 3 Samsung Galaxy A11 Daughterboard Replacement: step 6, image 3 of 3
    • If needed, use a hairdryer on low heat to soften the adhesive under the battery. If The Battery Is Expanded, DO NOT USE A HAIRDRYER or heat; be very careful when removing to not puncture the battery.
    • Use an iFixit pry tool to dig under the battery edge.
    • If needed, use multiple pry tools to hold the battery in place.
    • Continue to cut the adhesive under the battery until you are able to pry the battery away from the phone.
    • Remove the battery from the phone.
  7. Samsung Galaxy A11 Daughterboard Replacement, Daughterboard: step 7, image 1 of 3 Samsung Galaxy A11 Daughterboard Replacement, Daughterboard: step 7, image 2 of 3 Samsung Galaxy A11 Daughterboard Replacement, Daughterboard: step 7, image 3 of 3
    • Remove the eight silver and black 3 mm screws from the speaker cover using a Phillips #000 screwdriver.
    • Remove the speaker cover from the device.
  8. Samsung Galaxy A11 Daughterboard Replacement: step 8, image 1 of 3 Samsung Galaxy A11 Daughterboard Replacement: step 8, image 2 of 3 Samsung Galaxy A11 Daughterboard Replacement: step 8, image 3 of 3
    • Using a spudger, disconnect the antenna heads from the daughterboard.
    • Disconnect the ribbon cable from the daughterboard.
  9. Samsung Galaxy A11 Daughterboard Replacement: step 9, image 1 of 3 Samsung Galaxy A11 Daughterboard Replacement: step 9, image 2 of 3 Samsung Galaxy A11 Daughterboard Replacement: step 9, image 3 of 3
    • Using tweezers, gently pry the daughterboard from the device.
    • When using metal tools, it is important to be gentle in order to not damage the device.
3 other people completed this guide.
Kristen Gismondi
106,012 Reputation
267 Guides authored
iFixit Member of iFixit
Staff
123 Members
25,685 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 64
All Time: 612
