Samsung Galaxy A11 Battery Replacement
    1. Samsung Galaxy A11 Battery Replacement, Back Cover: step 1, image 1 of 3 Samsung Galaxy A11 Battery Replacement, Back Cover: step 1, image 2 of 3 Samsung Galaxy A11 Battery Replacement, Back Cover: step 1, image 3 of 3
      • Place the SIM eject tool in the hole of the sim tray.
      • Push until part of the SIM tray is pushed out.
      • Pull out the rest of the SIM tray.
      Ask FixBot
    2. Samsung Galaxy A11 Battery Replacement: step 2, image 1 of 3 Samsung Galaxy A11 Battery Replacement: step 2, image 2 of 3 Samsung Galaxy A11 Battery Replacement: step 2, image 3 of 3
      • Gently pry open the area of the back cover near the SIM tray using an iFixit opening pick.
      • Gently move the pick along the gap and pry open the clips holding it together.
      • If possible, use multiple picks to prevent the back cover from closing.
      Ask FixBot
    3. Samsung Galaxy A11 Battery Replacement: step 3, image 1 of 3 Samsung Galaxy A11 Battery Replacement: step 3, image 2 of 3 Samsung Galaxy A11 Battery Replacement: step 3, image 3 of 3
      • Using a hair dryer on low heat, heat the fingerprint sensor in increments of 30 seconds to loosen the surrounding adhesive.
      • Gently push the fingerprint sensor until it detaches from the back cover.
      • If needed, remove the button by prying it from the bottom of the device.
      Ask FixBot
    1. Samsung Galaxy A11 Battery Replacement, Battery: step 4, image 1 of 3 Samsung Galaxy A11 Battery Replacement, Battery: step 4, image 2 of 3 Samsung Galaxy A11 Battery Replacement, Battery: step 4, image 3 of 3
      • Remove the three 3 mm screws from the shield using a Phillips #000 screwdriver.
      • Remove the shield from the phone.
      Ask FixBot
    2. Samsung Galaxy A11 Battery Replacement: step 5, image 1 of 3 Samsung Galaxy A11 Battery Replacement: step 5, image 2 of 3 Samsung Galaxy A11 Battery Replacement: step 5, image 3 of 3
      • Using tweezers, a spudger, or your fingers, disconnect the battery press connector from the phone.
      Ask FixBot
    3. Samsung Galaxy A11 Battery Replacement: step 6, image 1 of 3 Samsung Galaxy A11 Battery Replacement: step 6, image 2 of 3 Samsung Galaxy A11 Battery Replacement: step 6, image 3 of 3
      • If needed, use a hairdryer on low heat to soften the adhesive under the battery. If The Battery Is Expanded, DO NOT USE A HAIRDRYER or heat; be very careful when removing to not puncture the battery.
      • Use an iFixit pry tool to dig under the battery edge.
      • If needed, use multiple pry tools to hold the battery in place.
      • Continue to cut the adhesive under the battery until you are able to pry the battery away from the phone.
      • Remove the battery from the phone.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. If you are planning to replace the battery, be sure to remove all remaining adhesive from the battery's spot. If possible, replace the adhesive when reassembling the device.
14 other people completed this guide.
Chloe Bulloch
813 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 40
Past 30 Days: 193
All Time: 3,026
