Samsung Galaxy A10 Battery Replacement
    1. Samsung Galaxy A10 Battery Replacement, Samsung Galaxy A10 SIM Tray Replacement: step 1, image 1 of 2 Samsung Galaxy A10 Battery Replacement, Samsung Galaxy A10 SIM Tray Replacement: step 1, image 2 of 2
      • Insert a SIM card eject tool, a SIM eject bit or a straightened paper clip into the hole on the SIM tray located at the left side of the phone.
      • Press firmly to eject the tray.
      Ask FixBot
    2. Samsung Galaxy A10 Battery Replacement: step 2, image 1 of 2 Samsung Galaxy A10 Battery Replacement: step 2, image 2 of 2
      • Remove the SIM card tray.
      • When reinserting the cards, make sure to properly orient them in the tray.
      Ask FixBot
    1. Samsung Galaxy A10 Battery Replacement, Back Cover: step 3, image 1 of 2 Samsung Galaxy A10 Battery Replacement, Back Cover: step 3, image 2 of 2
      • The back cover is held in place by plastic clips.
      • Insert an opening pick between the screen and the back cover on the bottom of the phone where the charging port is located.
      Ask FixBot
    2. Samsung Galaxy A10 Battery Replacement: step 4, image 1 of 3 Samsung Galaxy A10 Battery Replacement: step 4, image 2 of 3 Samsung Galaxy A10 Battery Replacement: step 4, image 3 of 3
      • Slide the opening pick to the bottom left corner to release the clips.
      Ask FixBot
    3. Samsung Galaxy A10 Battery Replacement: step 5, image 1 of 3 Samsung Galaxy A10 Battery Replacement: step 5, image 2 of 3 Samsung Galaxy A10 Battery Replacement: step 5, image 3 of 3
      • Slide the opening pick along the left edge to the top left corner of the phone, to release the clips.
      Ask FixBot
    4. Samsung Galaxy A10 Battery Replacement: step 6, image 1 of 3 Samsung Galaxy A10 Battery Replacement: step 6, image 2 of 3 Samsung Galaxy A10 Battery Replacement: step 6, image 3 of 3
      • Slide the opening pick from the top left corner to the top right corner to release the plastic clips.
      Ask FixBot
    5. Samsung Galaxy A10 Battery Replacement: step 7, image 1 of 3 Samsung Galaxy A10 Battery Replacement: step 7, image 2 of 3 Samsung Galaxy A10 Battery Replacement: step 7, image 3 of 3
      • Slide the opening pick from the top left corner to the bottom right corner to release the remaining clips.
      Ask FixBot
    6. Samsung Galaxy A10 Battery Replacement: step 8, image 1 of 2 Samsung Galaxy A10 Battery Replacement: step 8, image 2 of 2
      • Remove the back cover.
      Ask FixBot
    1. Samsung Galaxy A10 Battery Replacement, Samsung Galaxy A10 Motherboard Cover Replacement: step 9, image 1 of 1
      • Remove the three Phillips #00 screws (3 mm length).
      Ask FixBot
    2. Samsung Galaxy A10 Battery Replacement: step 10, image 1 of 3 Samsung Galaxy A10 Battery Replacement: step 10, image 2 of 3 Samsung Galaxy A10 Battery Replacement: step 10, image 3 of 3
      • Use the flat end of a spudger to pry up the motherboard cover to release the plastic clips which hold the cover in its place.
      • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, twist the spudger to make the process easier.
      • Remove the motherboard cover.
      • The remaining plastic clips should release during this process or can be unhinged easily by hand.
      Ask FixBot
    1. Samsung Galaxy A10 Battery Replacement, Battery Disconnect: step 11, image 1 of 2 Samsung Galaxy A10 Battery Replacement, Battery Disconnect: step 11, image 2 of 2
      • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
      Ask FixBot
    1. Samsung Galaxy A10 Battery Replacement, Battery: step 12, image 1 of 3 Samsung Galaxy A10 Battery Replacement, Battery: step 12, image 2 of 3 Samsung Galaxy A10 Battery Replacement, Battery: step 12, image 3 of 3
      • Use the flat end of a spudger to pry up and disconnect the interconnect and display flex cables from the motherboard.
      Ask FixBot
    2. Samsung Galaxy A10 Battery Replacement: step 13, image 1 of 1
      • Remove the eight Phillips #00 screws from the bottom (3 mm length).
      Ask FixBot
    3. Samsung Galaxy A10 Battery Replacement: step 14, image 1 of 1
      • Remove the daughterboard cover.
      Ask FixBot
    4. Samsung Galaxy A10 Battery Replacement: step 15, image 1 of 2 Samsung Galaxy A10 Battery Replacement: step 15, image 2 of 2
      • Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
      • Remove the interconnect cable.
      Ask FixBot
    5. Samsung Galaxy A10 Battery Replacement: step 16, image 1 of 1
      • Apply a heated iOpener to the screen to loosen the adhesive beneath the battery. Apply the iOpener for at least two minutes. You might need to repeat this procedure several times during the battery replacement.
      Ask FixBot
    6. Samsung Galaxy A10 Battery Replacement: step 17, image 1 of 3 Samsung Galaxy A10 Battery Replacement: step 17, image 2 of 3 Samsung Galaxy A10 Battery Replacement: step 17, image 3 of 3
      • Carefully bend the display cable away from the battery to make room for removal.
      • Take care to bend the cable only slightly.
      Ask FixBot
    7. Samsung Galaxy A10 Battery Replacement: step 18, image 1 of 3 Samsung Galaxy A10 Battery Replacement: step 18, image 2 of 3 Samsung Galaxy A10 Battery Replacement: step 18, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
      • Insert a plastic card underneath the bottom edge of the battery.
      • Carefully slide it underneath the battery to loosen the adhesive.
      • Continue sliding the plastic card underneath to pry up the battery from the bottom.
      Ask FixBot
    8. Samsung Galaxy A10 Battery Replacement: step 19, image 1 of 1
      • Remove the battery.
      • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard. Replace it with a new battery.
      • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
      Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
43 other people completed this guide.
Adriana Zwink
68,257 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,578 Guides authored
1 Guide Comment
Excellent assistance everything went according to your instructions, thanks a lot.
Chris Boughton - Reply Share
Past 24 Hours: 11
Past 7 Days: 107
Past 30 Days: 466
All Time: 91,582
