Samsung Galaxy A03s Screen Replacement
    1. Samsung Galaxy A03s Screen Replacement, Eject SIM card tray: step 1, image 1 of 1
      • Remove the sim card by inserting a sim card tool into the sim card tray hole.
      Ask FixBot
    2. Samsung Galaxy A03s Screen Replacement, Remove back cover: step 2, image 1 of 3 Samsung Galaxy A03s Screen Replacement, Remove back cover: step 2, image 2 of 3 Samsung Galaxy A03s Screen Replacement, Remove back cover: step 2, image 3 of 3
      • This cover has a series of plastic clips that attach it to the frame. Use your opening tool to gently pry the plastic back cover off.
      • Be careful inserting your opening tool near the power button. This button contains a fingerprint sensor with a ribbon cable that’s attached to the back cover. Do not cut this cable while removing the back cover.
      Ask FixBot
    3. Samsung Galaxy A03s Screen Replacement, Remove power button: step 3, image 1 of 1
      • 2 plastic notches on the back cover hold the power button in place. Disconnect the power button from the back cover.
      Ask FixBot
    4. Samsung Galaxy A03s Screen Replacement, Unfasten screws on camera lens bracket and loud speaker: step 4, image 1 of 2 Samsung Galaxy A03s Screen Replacement, Unfasten screws on camera lens bracket and loud speaker: step 4, image 2 of 2
      • 18 screws secure the camera lens bracket and loud speaker. All screws are the same size. Use a Phillips screwdriver to remove the 18 screws securing the camera lens bracket and loud speaker.
      Ask FixBot
    5. Samsung Galaxy A03s Screen Replacement, Remove camera lens bracket and loud speaker: step 5, image 1 of 3 Samsung Galaxy A03s Screen Replacement, Remove camera lens bracket and loud speaker: step 5, image 2 of 3 Samsung Galaxy A03s Screen Replacement, Remove camera lens bracket and loud speaker: step 5, image 3 of 3
      • Use your spudger to lift and remove the camera lens bracket and loud speaker.
      Ask FixBot
    6. Samsung Galaxy A03s Screen Replacement, Disconnect battery: step 6, image 1 of 2 Samsung Galaxy A03s Screen Replacement, Disconnect battery: step 6, image 2 of 2
      • Disconnect the battery cable by using a spudger
      Ask FixBot
    7. Samsung Galaxy A03s Screen Replacement, Disconnect and remove power button: step 7, image 1 of 2 Samsung Galaxy A03s Screen Replacement, Disconnect and remove power button: step 7, image 2 of 2
      • Use your spudger to disconnect the power button ribbon cable. Remove the power button.
      Ask FixBot
    8. Samsung Galaxy A03s Screen Replacement, Disconnect and remove mainboard cable: step 8, image 1 of 2 Samsung Galaxy A03s Screen Replacement, Disconnect and remove mainboard cable: step 8, image 2 of 2
      • Use your spudger to disconnect and remove the mainboard flex cable.
      Ask FixBot
    9. Samsung Galaxy A03s Screen Replacement, Disconnect and remove antenna cable: step 9, image 1 of 2 Samsung Galaxy A03s Screen Replacement, Disconnect and remove antenna cable: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to disconnect and remove the black antenna cable on the mainboard and charging board
      Ask FixBot
    10. Samsung Galaxy A03s Screen Replacement, Remove mainboard and charging board: step 10, image 1 of 2 Samsung Galaxy A03s Screen Replacement, Remove mainboard and charging board: step 10, image 2 of 2
      • Use your spudger to lift and remove mainboard and charging board
      Ask FixBot
    11. Samsung Galaxy A03s Screen Replacement, Remove vibrate motor: step 11, image 1 of 2 Samsung Galaxy A03s Screen Replacement, Remove vibrate motor: step 11, image 2 of 2
      • Use heat and/or isopropyl alcohol to remove vibrate motor
      Ask FixBot
    12. Samsung Galaxy A03s Screen Replacement, Remove volume button flex: step 12, image 1 of 2 Samsung Galaxy A03s Screen Replacement, Remove volume button flex: step 12, image 2 of 2
      • Use heat and/or isopropyl alcohol to remove volume button flex
      Ask FixBot
    13. Samsung Galaxy A03s Screen Replacement, Remove earpiece speaker: step 13, image 1 of 2 Samsung Galaxy A03s Screen Replacement, Remove earpiece speaker: step 13, image 2 of 2
      • Use spudger to remove earpiece speaker
      Ask FixBot
    14. Samsung Galaxy A03s Screen Replacement, Remove battery: step 14, image 1 of 1
      Plastic Cards
      $2.99
      Buy
      • Use heat and isopropyl alcohol to remove the battery.
      • Be careful to not puncture the battery while removing it.
      • There's a lot of adhesive under this battery and it can be tricky to remove. You can slide a thin plastic card underneath the battery to help break the adhesive.
      Ask FixBot
63 other people completed this guide.
Matea
2,017 Reputation
1 Guide authored
8 Guide Comments
Actually you guys are making it more complex and difficult than it needs to be or should ever have to be because I've repaired hundreds of Samsung Galaxy a03 s's and all Samsung Galaxy phones for that matter and the way you're going about in depth in detail and specific on a complete breakdown is too complex to be quite frankly honest with you you don't need to do all of this you're doing more work than what is really there honestly.
Harold Peterson - Reply Share
Are you going to offer the more simple solutions or no?
Missjentri - Reply Share
Yeah, so do a better job
Timothy Bradford - Reply Share
Can you post the simplest was to do this?
Chuck - Reply Share
No carga solo logo de temperatura
Alan Rivera - Reply Share
Past 24 Hours: 14
Past 7 Days: 157
Past 30 Days: 686
All Time: 33,710
