Up to 20% off select tools
Samsung Fascinate Camera Replacement
Views: 5.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
91
All Time:
5,189
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
This guide will show you how to disassemble the Samsung Galaxy S in order to get access to its camera unit.
    1. Samsung Fascinate Camera Replacement, Back Case: step 1, image 1 of 3 Samsung Fascinate Camera Replacement, Back Case: step 1, image 2 of 3 Samsung Fascinate Camera Replacement, Back Case: step 1, image 3 of 3
      • To remove the back case of the Samsung Galaxy S, you may need a spudger.
      • Identify the slit which is at the bottom edge of the phone.
      Ask FixBot
    2. Samsung Fascinate Camera Replacement: step 2, image 1 of 2 Samsung Fascinate Camera Replacement: step 2, image 2 of 2
      • Insert the edge of the spudger into the slit and use it to pry the back case off of the phone.
      Ask FixBot
    1. Samsung Fascinate Camera Replacement, Battery: step 3, image 1 of 2 Samsung Fascinate Camera Replacement, Battery: step 3, image 2 of 2
      • Insert the spudger into the space between the battery and the phone and pry the battery out as you slide it along the underside the battery.
      Ask FixBot
    1. Samsung Fascinate Camera Replacement, Speaker: step 4, image 1 of 3 Samsung Fascinate Camera Replacement, Speaker: step 4, image 2 of 3 Samsung Fascinate Camera Replacement, Speaker: step 4, image 3 of 3
      • Use the screwdriver to unscrew each of the 6 silver screws holding the main case to the LCD touchscreen.
      • If the screws are stuck, use the spudger to pry them out.
      Ask FixBot
    2. Samsung Fascinate Camera Replacement: step 5, image 1 of 3 Samsung Fascinate Camera Replacement: step 5, image 2 of 3 Samsung Fascinate Camera Replacement: step 5, image 3 of 3
      • Use the plastic opening tool to pry the main case from the LCD touchscreen.
      • Insert the thin edge of the plastic opening tool into the groove between the silver edge and black edge.
      • Run the tool all the way around the edge of the phone until you hear each of the clips detach.
      Ask FixBot
    3. Samsung Fascinate Camera Replacement: step 6, image 1 of 3 Samsung Fascinate Camera Replacement: step 6, image 2 of 3 Samsung Fascinate Camera Replacement: step 6, image 3 of 3
      • Once the clips are detached, separate the main case from the LCD touchscreen.
      Ask FixBot
    4. Samsung Fascinate Camera Replacement: step 7, image 1 of 3 Samsung Fascinate Camera Replacement: step 7, image 2 of 3 Samsung Fascinate Camera Replacement: step 7, image 3 of 3
      • Use the spudger to pry out the grey rubber rectangular component from the main case.
      Ask FixBot
    5. Samsung Fascinate Camera Replacement: step 8, image 1 of 3 Samsung Fascinate Camera Replacement: step 8, image 2 of 3 Samsung Fascinate Camera Replacement: step 8, image 3 of 3
      • Use the spudger to pry along the groove between the speaker and the main case.
      • Once the speaker is unclipped it should pop out easily.
      Ask FixBot
    1. Samsung Fascinate Camera Replacement, Camera: step 9, image 1 of 3 Samsung Fascinate Camera Replacement, Camera: step 9, image 2 of 3 Samsung Fascinate Camera Replacement, Camera: step 9, image 3 of 3
      • Using the plastic opening tool, you will need to detach the black square component which is boxed in blue.
      • Pry camera unit attached to it off the motherboard.
      Ask FixBot
3 other people completed this guide.
Author
with
Kevin Carlson
236 Reputation
6 Guides authored
Cal Poly, Team 25-25, Garner Spring 2011 Member of Cal Poly, Team 25-25, Garner Spring 2011
CPSU-GARNER-S11S25G25
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 91
All Time: 5,189
