Samsung Exhibit II 4G Rear Facing Camera Replacement
    1. Samsung Exhibit II 4G Rear Facing Camera Replacement, Battery: step 1, image 1 of 1
      • Insert plastic opening tool under back cover.
      • Apply pressure on tool while using a downward motion to pop off back cover.
      Ask FixBot
    2. Samsung Exhibit II 4G Rear Facing Camera Replacement: step 2, image 1 of 1
      • Insert plastic opening tool under battery.
      • Pry battery out.
      Ask FixBot
    1. Samsung Exhibit II 4G Rear Facing Camera Replacement, Top Rear Housing Cover: step 3, image 1 of 1
      • Pry the top cover upward to remove it from the phone.
      Ask FixBot
    2. Samsung Exhibit II 4G Rear Facing Camera Replacement: step 4, image 1 of 1
      • Remove the top cover.
      Ask FixBot
    3. Samsung Exhibit II 4G Rear Facing Camera Replacement: step 5, image 1 of 2 Samsung Exhibit II 4G Rear Facing Camera Replacement: step 5, image 2 of 2
      • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
      • Two screws from top and two screws from back.
      Ask FixBot
    4. Samsung Exhibit II 4G Rear Facing Camera Replacement: step 6, image 1 of 3 Samsung Exhibit II 4G Rear Facing Camera Replacement: step 6, image 2 of 3 Samsung Exhibit II 4G Rear Facing Camera Replacement: step 6, image 3 of 3
      • Insert plastic opening tool under top cover.
      • Using hand slide top cover away from phone.
      Ask FixBot
    1. Samsung Exhibit II 4G Rear Facing Camera Replacement, Midframe: step 7, image 1 of 1
      • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
      Ask FixBot
    2. Samsung Exhibit II 4G Rear Facing Camera Replacement: step 8, image 1 of 1
      • Insert plastic opening tool between back assembly and phone.
      • Pry the back assembly away from phone.
      Ask FixBot
    3. Samsung Exhibit II 4G Rear Facing Camera Replacement: step 9, image 1 of 1
      • With plastic opening tool continue prying around the edge of the back assembly.
      Ask FixBot
    4. Samsung Exhibit II 4G Rear Facing Camera Replacement: step 10, image 1 of 1
      • Pull back panel assembly away from main body.
      Ask FixBot
    1. Samsung Exhibit II 4G Rear Facing Camera Replacement, Rear Facing Camera: step 11, image 1 of 1
      • Use the flat end of a spudger to disconnect the camera assembly cable.
      Ask FixBot
    2. Samsung Exhibit II 4G Rear Facing Camera Replacement: step 12, image 1 of 2 Samsung Exhibit II 4G Rear Facing Camera Replacement: step 12, image 2 of 2
      • Remove camera from square housing.
      Ask FixBot
David R
1,152 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 28
All Time: 596
