Samsung Exhibit II 4G Motherboard Replacement
    1. Samsung Exhibit II 4G Motherboard Replacement, Battery: step 1, image 1 of 1
      • Insert plastic opening tool under back cover.
      • Apply pressure on tool while using a downward motion to pop off back cover.
      Ask FixBot
    2. Samsung Exhibit II 4G Motherboard Replacement: step 2, image 1 of 1
      • Insert plastic opening tool under battery.
      • Pry battery out.
      Ask FixBot
    1. Samsung Exhibit II 4G Motherboard Replacement, Top Rear Housing Cover: step 3, image 1 of 1
      • Pry the top cover upward to remove it from the phone.
      Ask FixBot
    2. Samsung Exhibit II 4G Motherboard Replacement: step 4, image 1 of 1
      • Remove the top cover.
      Ask FixBot
    3. Samsung Exhibit II 4G Motherboard Replacement: step 5, image 1 of 2 Samsung Exhibit II 4G Motherboard Replacement: step 5, image 2 of 2
      • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
      • Two screws from top and two screws from back.
      Ask FixBot
    4. Samsung Exhibit II 4G Motherboard Replacement: step 6, image 1 of 3 Samsung Exhibit II 4G Motherboard Replacement: step 6, image 2 of 3 Samsung Exhibit II 4G Motherboard Replacement: step 6, image 3 of 3
      • Insert plastic opening tool under top cover.
      • Using hand slide top cover away from phone.
      Ask FixBot
    1. Samsung Exhibit II 4G Motherboard Replacement, Midframe: step 7, image 1 of 1
      • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
      Ask FixBot
    2. Samsung Exhibit II 4G Motherboard Replacement: step 8, image 1 of 1
      • Insert plastic opening tool between back assembly and phone.
      • Pry the back assembly away from phone.
      Ask FixBot
    3. Samsung Exhibit II 4G Motherboard Replacement: step 9, image 1 of 1
      • With plastic opening tool continue prying around the edge of the back assembly.
      Ask FixBot
    4. Samsung Exhibit II 4G Motherboard Replacement: step 10, image 1 of 1
      • Pull back panel assembly away from main body.
      Ask FixBot
    1. Samsung Exhibit II 4G Motherboard Replacement, Vibration Motor: step 11, image 1 of 2 Samsung Exhibit II 4G Motherboard Replacement, Vibration Motor: step 11, image 2 of 2
      • Insert the pointed end of a spudger into the gap in the round housing frame.
      • Using spudger to remove vibrator remove from the adhesive.
      Ask FixBot
    2. Samsung Exhibit II 4G Motherboard Replacement: step 12, image 1 of 2 Samsung Exhibit II 4G Motherboard Replacement: step 12, image 2 of 2
      • Use the flat end of a spudger to remove vibrator cable from motherboard.
      Ask FixBot
    1. Samsung Exhibit II 4G Motherboard Replacement, Rear Facing Camera: step 13, image 1 of 1
      • Use the flat end of a spudger to disconnect the camera assembly cable.
      Ask FixBot
    2. Samsung Exhibit II 4G Motherboard Replacement: step 14, image 1 of 2 Samsung Exhibit II 4G Motherboard Replacement: step 14, image 2 of 2
      • Remove camera from square housing.
      Ask FixBot
    1. Samsung Exhibit II 4G Motherboard Replacement, Motherboard: step 15, image 1 of 3 Samsung Exhibit II 4G Motherboard Replacement, Motherboard: step 15, image 2 of 3 Samsung Exhibit II 4G Motherboard Replacement, Motherboard: step 15, image 3 of 3
      • Insert the spudger under each corner ribbon cable and lift them out of the way.
      • Use care when lifting the ribbon cables.
      • Insert a plastic pry tool into the gap between motherboard and base of phone
      Ask FixBot
    2. Samsung Exhibit II 4G Motherboard Replacement: step 16, image 1 of 3 Samsung Exhibit II 4G Motherboard Replacement: step 16, image 2 of 3 Samsung Exhibit II 4G Motherboard Replacement: step 16, image 3 of 3
      • Tilt the motherboard up carefully.
      • Be sure not to damage the ribbon cable still connected at the bottom of the motherboard.
      • Use a spudger to pry the connector from the socket on the motherboard.
      • Lift motherboard from frame.
      Ask FixBot
3 other people completed this guide.
David R
1,152 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 90
All Time: 1,055
