Samsung Exhibit II 4G Headphone Jack Replacement
  1. Samsung Exhibit II 4G Headphone Jack Replacement, Battery: step 1, image 1 of 1
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
    Ask FixBot
  2. Samsung Exhibit II 4G Headphone Jack Replacement: step 2, image 1 of 1
    • Insert plastic opening tool under battery.
    • Pry battery out.
    Ask FixBot
  3. Samsung Exhibit II 4G Headphone Jack Replacement, Top Rear Housing Cover: step 3, image 1 of 1
    • Pry the top cover upward to remove it from the phone.
    Ask FixBot
  4. Samsung Exhibit II 4G Headphone Jack Replacement: step 4, image 1 of 1
    • Remove the top cover.
    Ask FixBot
  5. Samsung Exhibit II 4G Headphone Jack Replacement: step 5, image 1 of 2 Samsung Exhibit II 4G Headphone Jack Replacement: step 5, image 2 of 2
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
    Ask FixBot
  6. Samsung Exhibit II 4G Headphone Jack Replacement: step 6, image 1 of 3 Samsung Exhibit II 4G Headphone Jack Replacement: step 6, image 2 of 3 Samsung Exhibit II 4G Headphone Jack Replacement: step 6, image 3 of 3
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
    Ask FixBot
  7. Samsung Exhibit II 4G Headphone Jack Replacement, Midframe: step 7, image 1 of 1
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
    Ask FixBot
  8. Samsung Exhibit II 4G Headphone Jack Replacement: step 8, image 1 of 1
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
    Ask FixBot
  9. Samsung Exhibit II 4G Headphone Jack Replacement: step 9, image 1 of 1
    • With plastic opening tool continue prying around the edge of the back assembly.
    Ask FixBot
  10. Samsung Exhibit II 4G Headphone Jack Replacement: step 10, image 1 of 1
    • Pull back panel assembly away from main body.
    Ask FixBot
  11. Samsung Exhibit II 4G Headphone Jack Replacement, Vibration Motor: step 11, image 1 of 2 Samsung Exhibit II 4G Headphone Jack Replacement, Vibration Motor: step 11, image 2 of 2
    • Insert the pointed end of a spudger into the gap in the round housing frame.
    • Using spudger to remove vibrator remove from the adhesive.
    Ask FixBot
  12. Samsung Exhibit II 4G Headphone Jack Replacement: step 12, image 1 of 2 Samsung Exhibit II 4G Headphone Jack Replacement: step 12, image 2 of 2
    • Use the flat end of a spudger to remove vibrator cable from motherboard.
    Ask FixBot
  13. Samsung Exhibit II 4G Headphone Jack Replacement, Rear Facing Camera: step 13, image 1 of 1
    • Use the flat end of a spudger to disconnect the camera assembly cable.
    Ask FixBot
  14. Samsung Exhibit II 4G Headphone Jack Replacement: step 14, image 1 of 2 Samsung Exhibit II 4G Headphone Jack Replacement: step 14, image 2 of 2
    • Remove camera from square housing.
    Ask FixBot
  15. Samsung Exhibit II 4G Headphone Jack Replacement, Motherboard: step 15, image 1 of 3 Samsung Exhibit II 4G Headphone Jack Replacement, Motherboard: step 15, image 2 of 3 Samsung Exhibit II 4G Headphone Jack Replacement, Motherboard: step 15, image 3 of 3
    • Insert the spudger under each corner ribbon cable and lift them out of the way.
    • Use care when lifting the ribbon cables.
    • Insert a plastic pry tool into the gap between motherboard and base of phone
    Ask FixBot
  16. Samsung Exhibit II 4G Headphone Jack Replacement: step 16, image 1 of 3 Samsung Exhibit II 4G Headphone Jack Replacement: step 16, image 2 of 3 Samsung Exhibit II 4G Headphone Jack Replacement: step 16, image 3 of 3
    • Tilt the motherboard up carefully.
    • Be sure not to damage the ribbon cable still connected at the bottom of the motherboard.
    • Use a spudger to pry the connector from the socket on the motherboard.
    • Lift motherboard from frame.
    Ask FixBot
  17. Samsung Exhibit II 4G Headphone Jack Replacement, Headphone Jack: step 17, image 1 of 3 Samsung Exhibit II 4G Headphone Jack Replacement, Headphone Jack: step 17, image 2 of 3 Samsung Exhibit II 4G Headphone Jack Replacement, Headphone Jack: step 17, image 3 of 3
    • Insert flat end of spudger between support panel and front assembly.
    • Using a spudger pry up to create opening to insert plastic opening tool.
    Ask FixBot
  18. Samsung Exhibit II 4G Headphone Jack Replacement: step 18, image 1 of 2 Samsung Exhibit II 4G Headphone Jack Replacement: step 18, image 2 of 2
    • Insert a plactic opening tool in opening.
    • Use plastic opening tool to pry around the edge of support panel to free it from front assembly.
    Ask FixBot
  19. Samsung Exhibit II 4G Headphone Jack Replacement: step 19, image 1 of 3 Samsung Exhibit II 4G Headphone Jack Replacement: step 19, image 2 of 3 Samsung Exhibit II 4G Headphone Jack Replacement: step 19, image 3 of 3
    • Insert the pointed end of a spudger into gap.
    • Lift spudger away from support plate to remove headphone component.
    Ask FixBot
  20. Samsung Exhibit II 4G Headphone Jack Replacement: step 20, image 1 of 3 Samsung Exhibit II 4G Headphone Jack Replacement: step 20, image 2 of 3 Samsung Exhibit II 4G Headphone Jack Replacement: step 20, image 3 of 3
    • Use the flat end of the spudger to remove headphone jack component from rectangular housing.
    Ask FixBot
David R
1,152 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 36
All Time: 557
