Samsung Eternity Motherboard Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
9
Past 30 Days:
38
All Time:
2,701
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 25 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
You will need to find a clean area to work in and have the necessary tools. Follow this guide to gain access to your cellphone's motherboard.
Tools
      • Remove the back battery cover.
      Ask FixBot
    1. Samsung Eternity Motherboard Replacement: step 2, image 1 of 1
      • Using a nylon spudger, remove the phone's battery.
      Ask FixBot
    2. Samsung Eternity Motherboard Replacement: step 3, image 1 of 1
      • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
      Ask FixBot
    3. Samsung Eternity Motherboard Replacement: step 4, image 1 of 2 Samsung Eternity Motherboard Replacement: step 4, image 2 of 2
      • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
      Ask FixBot
    1. Samsung Eternity Motherboard Replacement, Motherboard: step 5, image 1 of 1
      • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
      • Pull the antenna plug out of its socket.
      Ask FixBot
    2. Samsung Eternity Motherboard Replacement: step 6, image 1 of 3 Samsung Eternity Motherboard Replacement: step 6, image 2 of 3 Samsung Eternity Motherboard Replacement: step 6, image 3 of 3
      • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
      Ask FixBot
    3. Samsung Eternity Motherboard Replacement: step 7, image 1 of 1
      • Pop the red hinged-release lever away from its ribbon. Then pull it out.
      Ask FixBot
    4. Samsung Eternity Motherboard Replacement: step 8, image 1 of 1
      • Peel the button sensor on the side of the motherboard off of the case.
      Ask FixBot
    5. Samsung Eternity Motherboard Replacement: step 9, image 1 of 3 Samsung Eternity Motherboard Replacement: step 9, image 2 of 3 Samsung Eternity Motherboard Replacement: step 9, image 3 of 3
      • Slightly pull up one side of the motherboard.
      • Pull the button/microphone plug out of its socket.
      • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
      Ask FixBot
    6. Samsung Eternity Motherboard Replacement: step 10, image 1 of 1
      • You have successfully removed the motherboard from the phone.
      Ask FixBot
Kevin Huang
11 Reputation
1 Guide authored
Cal Poly, Team 15-11, Regan Spring 2011 Member of Cal Poly, Team 15-11, Regan Spring 2011
CPSU-REGAN-S11S15G11
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 38
All Time: 2,701
