Up to 20% off select tools
Samsung Eternity Input Jack Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
12
Past 30 Days:
87
All Time:
2,092
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
You will need to find a clean area to work in and have the necessary tools. Follow this guide to gain access to your cellphone's input jack module.
      • Remove the back battery cover.
      Ask FixBot
    1. Samsung Eternity Input Jack Replacement: step 2, image 1 of 1
      • Using a nylon spudger, remove the phone's battery.
      Ask FixBot
    2. Samsung Eternity Input Jack Replacement: step 3, image 1 of 1
      • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
      Ask FixBot
    3. Samsung Eternity Input Jack Replacement: step 4, image 1 of 2 Samsung Eternity Input Jack Replacement: step 4, image 2 of 2
      • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
      Ask FixBot
    1. Samsung Eternity Input Jack Replacement, Input Jack: step 5, image 1 of 1
      • Peel off the Identification sticker
      Ask FixBot
    2. Samsung Eternity Input Jack Replacement: step 6, image 1 of 1
      • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
      Ask FixBot
    3. Samsung Eternity Input Jack Replacement: step 7, image 1 of 1
      • Pop the speaker plug out of its socket.
      Ask FixBot
    4. Samsung Eternity Input Jack Replacement: step 8, image 1 of 1
      • Peel the button sensor off the top of the case.
      Ask FixBot
    5. Samsung Eternity Input Jack Replacement: step 9, image 1 of 1
      • Peel the Input jack assembly out of the case.
      Ask FixBot
Author
with
Sven
55 Reputation
1 Guide authored
Cal Poly, Team 15-11, Regan Spring 2011 Member of Cal Poly, Team 15-11, Regan Spring 2011
CPSU-REGAN-S11S15G11
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 87
All Time: 2,092
