Up to 20% off select tools
Samsung Eternity Back Case Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
81
All Time:
2,254
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
  • Spudger
    4.9
  • Phillips #00 Screwdriver
    4.9
Introduction
Go to step 1 ↓
You will need a clean area to work in with a wide, flat surface. You will also need the necessary tools to complete this repair. This goal of this guide is to replace the back case of your Samsung Eternity. No special skills are required, just access to the necessary tools and a space to work in.
      • Remove the back battery cover.
      Ask FixBot
    1. Samsung Eternity Back Case Replacement: step 2, image 1 of 1
      • Using a nylon spudger, remove the phone's battery.
      Ask FixBot
    2. Samsung Eternity Back Case Replacement: step 3, image 1 of 1
      • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
      Ask FixBot
    3. Samsung Eternity Back Case Replacement: step 4, image 1 of 2 Samsung Eternity Back Case Replacement: step 4, image 2 of 2
      • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
      Ask FixBot
Author
with
Michelle Haddock
51 Reputation
3 Guides authored
Cal Poly, Team 15-11, Regan Spring 2011 Member of Cal Poly, Team 15-11, Regan Spring 2011
CPSU-REGAN-S11S15G11
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 81
All Time: 2,254
