Samsung Eternity Antenna/Speaker Replacement
    • Remove the back battery cover.
    Ask FixBot
  1. Samsung Eternity Antenna/Speaker Replacement: step 2, image 1 of 1
    • Using a nylon spudger, remove the phone's battery.
    Ask FixBot
  2. Samsung Eternity Antenna/Speaker Replacement: step 3, image 1 of 1
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
    Ask FixBot
  3. Samsung Eternity Antenna/Speaker Replacement: step 4, image 1 of 2 Samsung Eternity Antenna/Speaker Replacement: step 4, image 2 of 2
    • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
    Ask FixBot
  4. Samsung Eternity Antenna/Speaker Replacement, Antenna/Speaker: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Pop the antenna plug off of its socket with a pair of metal tweezers.
    Ask FixBot
  5. Samsung Eternity Antenna/Speaker Replacement: step 6, image 1 of 1
    • Peel off the Identification sticker.
    Ask FixBot
  6. Samsung Eternity Antenna/Speaker Replacement: step 7, image 1 of 1
    • Peel the button sensor on the side of the motherboard off of the case.
    Ask FixBot
  7. Samsung Eternity Antenna/Speaker Replacement: step 8, image 1 of 1
    • Pop the speaker plug out of its socket.
    Ask FixBot
  8. Samsung Eternity Antenna/Speaker Replacement: step 9, image 1 of 1
    • Pry the antenna/speaker component out of its casing. You need to use a little force to get the piece to pop out.
    Ask FixBot
  9. Samsung Eternity Antenna/Speaker Replacement: step 10, image 1 of 1
    • You will now be able to replace the antenna/speaker module.
    Ask FixBot
2 other people completed this guide.
Matthew Kidd
76 Reputation
1 Guide authored
Cal Poly, Team 15-11, Regan Spring 2011 Member of Cal Poly, Team 15-11, Regan Spring 2011
CPSU-REGAN-S11S15G11
5 Members
21 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 3,151
