Up to 20% off select tools
Samsung Epix LCD Display Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
92
All Time:
2,571
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
This guide shows you how to access the LCD display inside your phone.
    1. Samsung Epix LCD Display Replacement, Battery: step 1, image 1 of 1
      • Just below the phone's camera, press the button and hold it
      • While the button is held down, slide the back panel off to remove it completely.
      Ask FixBot
    2. Samsung Epix LCD Display Replacement: step 2, image 1 of 1
      • Grasp the bottom corners of the battery with two fingers and gently lift.
      • Gently lift the battery and remove it from the phone.
      Ask FixBot
    1. Samsung Epix LCD Display Replacement, LCD Display: step 3, image 1 of 1
      • Remove the rubber screw cover in the top left corner by prying upwards with an opening tool.
      Ask FixBot
    2. Samsung Epix LCD Display Replacement: step 4, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone.
      • The upper right screw is 4.5 mm and the others are 6.5 mm.
      Ask FixBot
    3. Samsung Epix LCD Display Replacement: step 5, image 1 of 2 Samsung Epix LCD Display Replacement: step 5, image 2 of 2
      • Slide the opening tool along the seam on the side of the phone and turn it slightly to unhook the eight clips.
      • There are three clips on each side and two at the bottom of the phone.
      Ask FixBot
    4. Samsung Epix LCD Display Replacement: step 6, image 1 of 1
      • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
      • Be careful not to remove the front panel. It will still be connected to the phone chassis by a ribbon cable on the motherboard.
      Ask FixBot
    5. Samsung Epix LCD Display Replacement: step 7, image 1 of 1
      • Using an opening tool, undo the ZIF connector halfway up the right side.
      • Carefully remove ribbon cable.
      Ask FixBot
    6. Samsung Epix LCD Display Replacement: step 8, image 1 of 1
      • Remove the front faceplate by lifting it off of the phone chassis.
      Ask FixBot
    7. Samsung Epix LCD Display Replacement: step 9, image 1 of 1
      • Using the opening tool, unlatch the LCD ribbon cable.
      Ask FixBot
    8. Samsung Epix LCD Display Replacement: step 10, image 1 of 1
      • Using an opening tool or spudger, pry under the lower left and right corners of the LCD screen.
      • The LCD is held in place to the chassis with adhesive strips.
      • Do not pry excessively hard. You may damage the circuitry on the back of the LCD.
      Ask FixBot
    9. Samsung Epix LCD Display Replacement: step 11, image 1 of 1
      • Lift the LCD display out from phone chassis.
      Ask FixBot
Author
with
Mark Wyse
62 Reputation
2 Guides authored
Cal Poly, Team 15-15, Regan Spring 2011 Member of Cal Poly, Team 15-15, Regan Spring 2011
CPSU-REGAN-S11S15G15
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 92
All Time: 2,571
