Samsung Epic 4G Touch microSD Card Replacement
    1. Samsung Epic 4G Touch microSD Card Replacement, Rear Case: step 1, image 1 of 2 Samsung Epic 4G Touch microSD Card Replacement, Rear Case: step 1, image 2 of 2
      • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
      • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
      Ask FixBot
    2. Samsung Epic 4G Touch microSD Card Replacement: step 2, image 1 of 2 Samsung Epic 4G Touch microSD Card Replacement: step 2, image 2 of 2
      • Lift and remove the rear case.
      Ask FixBot
    1. Samsung Epic 4G Touch microSD Card Replacement, microSD Card: step 3, image 1 of 2 Samsung Epic 4G Touch microSD Card Replacement, microSD Card: step 3, image 2 of 2
      • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
      • After the click, release the card and it will pop out of its slot.
      • During reassembly, push the microSD card into the slot until it clicks in place.
      Ask FixBot
    2. Samsung Epic 4G Touch microSD Card Replacement: step 4, image 1 of 1
      • Pull the microSD card away from its slot.
      Ask FixBot
3 other people completed this guide.
2 Guide Comments
Uhh.... my Australian SGSII looks different to this...
Bonj - Reply Share
If you are having trouble addint a 64gb micro sd card, it's because you have to first format that card to FAT32. You have to do that to the memory card through a computer. Youtube too, it'll help
asff - Reply Share
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 108
All Time: 4,987
