Up to 20% off select tools
Samsung Epic 4G Power Button Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
84
All Time:
3,087
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
  • Phillips #000 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide details how to install a new power button into your Samsung Epic 4G. Directions are provided for both disassembly and reassembly.
    1. Samsung Epic 4G Power Button Replacement, Phone Case: step 1, image 1 of 1
      • Slide your fingernail along the edge of the device and pull at the plastic backing.
      • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
      Ask FixBot
    2. Samsung Epic 4G Power Button Replacement: step 2, image 1 of 1
      • Pull at the plastic backing gently to remove it after hearing the snap sound.
      Ask FixBot
    1. Samsung Epic 4G Power Button Replacement, Battery: step 3, image 1 of 1
      • Remove the battery from the device by pulling the battery edge upwards.
      Ask FixBot
    1. Samsung Epic 4G Power Button Replacement, Removing the Memory Card:: step 4, image 1 of 1
      • Locate the memory card on the upper right-hand corner of the device.
      • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
      Ask FixBot
    2. Samsung Epic 4G Power Button Replacement, Removing the Back Housing: step 5, image 1 of 2 Samsung Epic 4G Power Button Replacement, Removing the Back Housing: step 5, image 2 of 2
      • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
      • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
      • While separating the two components, most of the buttons (including the power button) will fall out.
      Ask FixBot
    3. Samsung Epic 4G Power Button Replacement, Removing the Power Button: step 6, image 1 of 2 Samsung Epic 4G Power Button Replacement, Removing the Power Button: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the power button using tweezers if it did not fall out in the previous step.
      • At this point, you can replace the power button with a new one from a manufacturer.
      Ask FixBot
Author
with
Andrew Cunningham
273 Reputation
6 Guides authored
Cal Poly, Team 24-25, Regan Fall 2012 Member of Cal Poly, Team 24-25, Regan Fall 2012
CPSU-REGAN-F12S24G25
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 84
All Time: 3,087
