Samsung Epic 4G Micro USB Port Replacement
    1. Samsung Epic 4G Micro USB Port Replacement, Phone Case: step 1, image 1 of 1
      • Slide your fingernail along the edge of the device and pull at the plastic backing.
      • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
      Ask FixBot
    2. Samsung Epic 4G Micro USB Port Replacement: step 2, image 1 of 1
      • Pull at the plastic backing gently to remove it after hearing the snap sound.
      Ask FixBot
    1. Samsung Epic 4G Micro USB Port Replacement, Battery: step 3, image 1 of 1
      • Remove the battery from the device by pulling the battery edge upwards.
      Ask FixBot
    1. Samsung Epic 4G Micro USB Port Replacement, Removing the Memory Card:: step 4, image 1 of 1
      • Locate the memory card on the upper right-hand corner of the device.
      • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
      Ask FixBot
    2. Samsung Epic 4G Micro USB Port Replacement, Removing the Back Housing: step 5, image 1 of 2 Samsung Epic 4G Micro USB Port Replacement, Removing the Back Housing: step 5, image 2 of 2
      • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
      • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
      • While separating the two components, most of the buttons (including the power button) will fall out.
      Ask FixBot
    3. Samsung Epic 4G Micro USB Port Replacement, Removing the Power Button: step 6, image 1 of 2 Samsung Epic 4G Micro USB Port Replacement, Removing the Power Button: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the power button using tweezers if it did not fall out in the previous step.
      • At this point, you can replace the power button with a new one from a manufacturer.
      Ask FixBot
    1. Samsung Epic 4G Micro USB Port Replacement, Micro USB Port: step 7, image 1 of 1
      • Remove the white cable along the right side of the device (next to the battery housing) using the nylon spudger.
      • Pull out both ends of the white cable. They will easily snap out of place without excessive tension.
      • Do not rip the white cables out of the device.
      Ask FixBot
    2. Samsung Epic 4G Micro USB Port Replacement, Removing the Antenna Assembly: step 8, image 1 of 2 Samsung Epic 4G Micro USB Port Replacement, Removing the Antenna Assembly: step 8, image 2 of 2
      • Remove the screw holding the antenna assembly in place using a Tri-Point Y0 screwdriver.
      • Snap the antenna assembly out of the device gently using your fingers.
      Ask FixBot
    3. Samsung Epic 4G Micro USB Port Replacement, Removing the Flex Cable: step 9, image 1 of 2 Samsung Epic 4G Micro USB Port Replacement, Removing the Flex Cable: step 9, image 2 of 2
      • Pry the flex cable from the top of the phone by carefully using a nylon spudger.
      • Repeat this step for the larger flex cable located on the left side of the device below the smaller one.
      Ask FixBot
    4. Samsung Epic 4G Micro USB Port Replacement: step 10, image 1 of 1
      • Lift and remove the motherboard from the device.
      • The USB port is located at the top of the motherboard. At this point, replace the port with a new one from a manufacturer.
      Ask FixBot
8 other people completed this guide.
Andrew Cunningham
273 Reputation
6 Guides authored
Cal Poly, Team 24-25, Regan Fall 2012 Member of Cal Poly, Team 24-25, Regan Fall 2012
CPSU-REGAN-F12S24G25
4 Members
84 Guides authored
1 Guide Comment
My phone doesn’t have a memory card. At least, not that I can see. What should I do?
Joshua Campbell - Reply Share
Past 24 Hours: 2
Past 7 Days: 30
Past 30 Days: 100
All Time: 3,003
