Samsung DVD-P230 LCD Screen Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
87
All Time:
3,551
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Very difficult
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Samsung DVD-P230 LCD Screen Replacement, Outer Cover & Faceplate: step 1, image 1 of 3 Samsung DVD-P230 LCD Screen Replacement, Outer Cover & Faceplate: step 1, image 2 of 3 Samsung DVD-P230 LCD Screen Replacement, Outer Cover & Faceplate: step 1, image 3 of 3
      • Open the tray by pressing the eject button
      • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
      Ask FixBot
    2. Samsung DVD-P230 LCD Screen Replacement: step 2, image 1 of 1
      • Press the eject button to insert the tray
      • After the tray is closed unplug DVD player
      Ask FixBot
    3. Samsung DVD-P230 LCD Screen Replacement: step 3, image 1 of 1
      • Unscrew the 3 screws in the back.
      Ask FixBot
    4. Samsung DVD-P230 LCD Screen Replacement: step 4, image 1 of 2 Samsung DVD-P230 LCD Screen Replacement: step 4, image 2 of 2
      • Pull the outer case upward and then towards you.
      Ask FixBot
    5. Samsung DVD-P230 LCD Screen Replacement: step 5, image 1 of 3 Samsung DVD-P230 LCD Screen Replacement: step 5, image 2 of 3 Samsung DVD-P230 LCD Screen Replacement: step 5, image 3 of 3
      • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
      Ask FixBot
    6. Samsung DVD-P230 LCD Screen Replacement: step 6, image 1 of 2 Samsung DVD-P230 LCD Screen Replacement: step 6, image 2 of 2
      • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
      Ask FixBot
    1. Samsung DVD-P230 LCD Screen Replacement, Power Cord: step 7, image 1 of 3 Samsung DVD-P230 LCD Screen Replacement, Power Cord: step 7, image 2 of 3 Samsung DVD-P230 LCD Screen Replacement, Power Cord: step 7, image 3 of 3
      • Locate the white clip that attaches the cord to the motherboard
      • Grasp clip and squeeze to release
      • Lift up and remove power cord
      • Slide cord mount from outer case
      Ask FixBot
    1. Samsung DVD-P230 LCD Screen Replacement, Tray: step 8, image 1 of 3 Samsung DVD-P230 LCD Screen Replacement, Tray: step 8, image 2 of 3 Samsung DVD-P230 LCD Screen Replacement, Tray: step 8, image 3 of 3
      • Remove the three screws holding in the DVD tray
      Ask FixBot
    2. Samsung DVD-P230 LCD Screen Replacement: step 9, image 1 of 2 Samsung DVD-P230 LCD Screen Replacement: step 9, image 2 of 2
      • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
      Ask FixBot
    3. Samsung DVD-P230 LCD Screen Replacement: step 10, image 1 of 2 Samsung DVD-P230 LCD Screen Replacement: step 10, image 2 of 2
      • Gently lift the DVD tray off of the motherboard.
      Ask FixBot
    1. Samsung DVD-P230 LCD Screen Replacement, Motherboard: step 11, image 1 of 2 Samsung DVD-P230 LCD Screen Replacement, Motherboard: step 11, image 2 of 2
      • Unscrew the 2 screws on the motherboard
      • Unscrew the 2 screws on the back
      Ask FixBot
    2. Samsung DVD-P230 LCD Screen Replacement: step 12, image 1 of 3 Samsung DVD-P230 LCD Screen Replacement: step 12, image 2 of 3 Samsung DVD-P230 LCD Screen Replacement: step 12, image 3 of 3
      • Disconnect the wires and ribbon by pulling them out of their respective connections
      Ask FixBot
    3. Samsung DVD-P230 LCD Screen Replacement: step 13, image 1 of 2 Samsung DVD-P230 LCD Screen Replacement: step 13, image 2 of 2
      • Lift board up and out of the lower case
      Ask FixBot
    1. Samsung DVD-P230 LCD Screen Replacement, LCD Screen: step 14, image 1 of 2 Samsung DVD-P230 LCD Screen Replacement, LCD Screen: step 14, image 2 of 2
      • The LCD screen has pins attaching it to the motherboard. Flip the motherboard over.
      • De-solder LCD screen pins from the motherboard.
      • Pinch black tabs to remove LCD screen from motherboard.
      • Solder the new LCD screen pins into motherboard.
      Ask FixBot
Evan Domingue
410 Reputation
3 Guides authored
Cal Poly, Team 3-30, Regan Winter 2011 Member of Cal Poly, Team 3-30, Regan Winter 2011
CPSU-REGAN-W11S3G30
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 87
All Time: 3,551
