Samsung DVD-HD850 Player Power Button Replacement
    1. Samsung DVD-HD850 Player Power Button Replacement, Cover: step 1, image 1 of 1
      • with the front of the device facing you, turn the device 180 degrees so the back panel of the device is facing you
      Ask FixBot
    2. Samsung DVD-HD850 Player Power Button Replacement, Locate and remove screws: step 2, image 1 of 1
      • locate the three (3) screws on the back panel of the device that are implanted in the device
      • to remove the screws, use the tool(s) listed above (right underneath the introduction) and twist the screws counter-clockwise to remove them from the device
      Ask FixBot
    3. Samsung DVD-HD850 Player Power Button Replacement, Remove Cover: step 3, image 1 of 1
      • to remove the cover of the device, pull the cover towards the back of the device until it is completely removed so you can see the insides of the device
      Ask FixBot
    1. Samsung DVD-HD850 Player Power Button Replacement, Locate and Remove The Disk Tray: step 4, image 1 of 1
      • *NOTE* remember to never connect to power when working on electrical components
      • Find and locate the disk tray it is located top right hand side of the component when the back of the device ( dvd player ) is facing you.
      Ask FixBot
    2. Samsung DVD-HD850 Player Power Button Replacement, Removing The Data Strips: step 5, image 1 of 1
      • Locate and gently remove the data strips on the tray. There are three in total, two on the left hand side and one on the right.
      Ask FixBot
    3. Samsung DVD-HD850 Player Power Button Replacement, Removing The Screws: step 6, image 1 of 3 Samsung DVD-HD850 Player Power Button Replacement, Removing The Screws: step 6, image 2 of 3 Samsung DVD-HD850 Player Power Button Replacement, Removing The Screws: step 6, image 3 of 3
      • As noted by the red circles, locate and remove the screws one at a time
      Ask FixBot
    4. Samsung DVD-HD850 Player Power Button Replacement, Disk Tray Removal: step 7, image 1 of 1
      • After removing the clips slowly incline the disk drive towards you and unclip it from the two (2) brackets located on the top
      • Be careful not to push too much pressure on the brackets since they tend to break easily
      Ask FixBot
    5. Samsung DVD-HD850 Player Power Button Replacement, Success!: step 8, image 1 of 1
      • Congrats! You have sucessfully have taken out the disk drive
      Ask FixBot
    1. Samsung DVD-HD850 Player Power Button Replacement, Unscrew power button circuit board: step 9, image 1 of 1
      • Unscrew the one screw that is connecting the circuit board to the frame.
      Ask FixBot
    2. Samsung DVD-HD850 Player Power Button Replacement, Remove power button circuit board: step 10, image 1 of 1
      • Jiggle the circuit board until it becomes loose from the two prongs holding it in place.
      • Replace with a new one.
      Ask FixBot
Robert Moss
201 Reputation
2 Guides authored
UMass Dartmouth, Team 1-6, Duarte Fall 2014 Member of UMass Dartmouth, Team 1-6, Duarte Fall 2014
UMASSD-DUARTE-F14S1G6
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 10
Past 30 Days: 31
All Time: 629
