Samsung DVD-HD850 Player Cover Replacement
  1. Samsung DVD-HD850 Player Cover Replacement, Cover: step 1, image 1 of 1
    • with the front of the device facing you, turn the device 180 degrees so the back panel of the device is facing you
    Ask FixBot
  2. Samsung DVD-HD850 Player Cover Replacement, Locate and remove screws: step 2, image 1 of 1
    • locate the three (3) screws on the back panel of the device that are implanted in the device
    • to remove the screws, use the tool(s) listed above (right underneath the introduction) and twist the screws counter-clockwise to remove them from the device
    Ask FixBot
  3. Samsung DVD-HD850 Player Cover Replacement, Remove Cover: step 3, image 1 of 1
    • to remove the cover of the device, pull the cover towards the back of the device until it is completely removed so you can see the insides of the device
    Ask FixBot
Devon Clements
228 Reputation
2 Guides authored
UMass Dartmouth, Team 1-6, Duarte Fall 2014 Member of UMass Dartmouth, Team 1-6, Duarte Fall 2014
UMASSD-DUARTE-F14S1G6
3 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 19
All Time: 634
