Samsung DP515A2G Hard Disk Drive Replacement
    1. Samsung DP515A2G Hard Disk Drive Replacement, Hard Disk Drive: step 1, image 1 of 2 Samsung DP515A2G Hard Disk Drive Replacement, Hard Disk Drive: step 1, image 2 of 2
      • Put the Samsung dp515a2g face down on a surface that will not scratch the monitor.
      Ask FixBot
    2. Samsung DP515A2G Hard Disk Drive Replacement: step 2, image 1 of 2 Samsung DP515A2G Hard Disk Drive Replacement: step 2, image 2 of 2
      Tool used on this step:
      iFixit Opening Picks (Set of 6)
      $4.95
      Buy
      • Gently insert an opening pick in the seam between the back panel and bezel.
      • Run the opening pick along the seam, carefully freeing the clips holding the back panel in place.
      • The back panel should come away without resistance.
      Ask FixBot
    3. Samsung DP515A2G Hard Disk Drive Replacement: step 3, image 1 of 1
      Phillips #000 Screwdriver
      $5.49
      Buy
      Ask FixBot
    4. Samsung DP515A2G Hard Disk Drive Replacement: step 4, image 1 of 2 Samsung DP515A2G Hard Disk Drive Replacement: step 4, image 2 of 2
      • Once the shroud surrounding the hard drive is free, disconnect the hard drive by grasping the connector with one hand, and the shroud with the other hand and gently pull them apart.
      • Do not put the wires connecting the hard drive.
      Ask FixBot
    5. Samsung DP515A2G Hard Disk Drive Replacement: step 5, image 1 of 3 Samsung DP515A2G Hard Disk Drive Replacement: step 5, image 2 of 3 Samsung DP515A2G Hard Disk Drive Replacement: step 5, image 3 of 3
      $5.49
      Buy
      • Using the 000 Screwdriver remove the screw on each side.
      • The hard drive should pull free of the shroud.
      Ask FixBot
4 other people completed this guide.
gatewaynomad
1,177 Reputation
1 Guide authored
Repair-O-Tech Member of Repair-O-Tech
Business
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 90
All Time: 1,716
