Samsung Chromebook XE550C22 Back Panel Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
97
All Time:
906
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Replace the back panel on a Chromebook XE550C22.
Tools
    1. Samsung Chromebook XE550C22 Back Panel Replacement, Back Panel: step 1, image 1 of 3 Samsung Chromebook XE550C22 Back Panel Replacement, Back Panel: step 1, image 2 of 3 Samsung Chromebook XE550C22 Back Panel Replacement, Back Panel: step 1, image 3 of 3
      • Turn the power off before beginning this step.
      • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
      Ask FixBot
    2. Samsung Chromebook XE550C22 Back Panel Replacement: step 2, image 1 of 2 Samsung Chromebook XE550C22 Back Panel Replacement: step 2, image 2 of 2
      • Remove the eight 7mm screws using the J0 Screwdriver.
      Ask FixBot
    3. Samsung Chromebook XE550C22 Back Panel Replacement: step 3, image 1 of 3 Samsung Chromebook XE550C22 Back Panel Replacement: step 3, image 2 of 3 Samsung Chromebook XE550C22 Back Panel Replacement: step 3, image 3 of 3
      • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
      • Continue prying around the sides to release more brackets.
      Ask FixBot
    4. Samsung Chromebook XE550C22 Back Panel Replacement: step 4, image 1 of 2 Samsung Chromebook XE550C22 Back Panel Replacement: step 4, image 2 of 2
      • After deconnecting all the brackets, pull the back panel away from the laptop.
      • Note: The back panel has some flex to it, don't be afraid to use some force.
      Ask FixBot
3 other people completed this guide.
Brenna Wolfe
541 Reputation
3 Guides authored
CSU Fullerton, Team S2-G7, Bruce Fall 2017 Member of CSU Fullerton, Team S2-G7, Bruce Fall 2017
CSUF-BRUCE-F17S2G7
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 97
All Time: 906
