Samsung Chromebook Series 3 Front Camera Replacement
    1. Samsung Chromebook Series 3 Front Camera Replacement, Screen: step 1, image 1 of 3 Samsung Chromebook Series 3 Front Camera Replacement, Screen: step 1, image 2 of 3 Samsung Chromebook Series 3 Front Camera Replacement, Screen: step 1, image 3 of 3
      • Use the iFixit opening tool to get under the front cover and pop it out of place
      Ask FixBot
    2. Samsung Chromebook Series 3 Front Camera Replacement: step 2, image 1 of 3 Samsung Chromebook Series 3 Front Camera Replacement: step 2, image 2 of 3 Samsung Chromebook Series 3 Front Camera Replacement: step 2, image 3 of 3
      • Remove the four 2.9 mm screws with the Phillips #00 Screwdriver bit.
      • Using the iFixit opening tool, try to lift up the screen (it is held down by some adhesive).
      Ask FixBot
    3. Samsung Chromebook Series 3 Front Camera Replacement: step 3, image 1 of 3 Samsung Chromebook Series 3 Front Camera Replacement: step 3, image 2 of 3 Samsung Chromebook Series 3 Front Camera Replacement: step 3, image 3 of 3
      • Lift the lever to release the cable and pull the cable out.
      Ask FixBot
    4. Samsung Chromebook Series 3 Front Camera Replacement: step 4, image 1 of 1
      • You can now remove the screen.
      Ask FixBot
    1. Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: step 5, image 1 of 3 Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: step 5, image 2 of 3 Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: step 5, image 3 of 3
      • Disconnect the ribbon cable connected to the front camera assembly.
      • You will need to flip up the little black lever to release the cable.
      Ask FixBot
    2. Samsung Chromebook Series 3 Front Camera Replacement: step 6, image 1 of 2 Samsung Chromebook Series 3 Front Camera Replacement: step 6, image 2 of 2
      • Use an iFixit opening tool to pry the front camera assembly from the adhesive holding it in place.
      Ask FixBot
Tyler Schultz
630 Reputation
3 Guides authored
IUPUI, Team S2-G1, Henning Spring 2019 Member of IUPUI, Team S2-G1, Henning Spring 2019
IUPUI-HENNING-S19S2G1
3 Members
36 Guides authored
1 Guide Comment
Thanks for posting this! I looked all over youtube and couldn’t find anything so I am relieved to find this tutorial! I haven’t performed the repair yet, but I was wondering if removing the screen is necessary. From what I see, I can access the camera by just removing the bezel. Thanks for your feedback in advance!
Angel Knepper - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 29
All Time: 958
