Samsung Chromebook Pro Hinge Replacement
    1. Samsung Chromebook Pro Hinge Replacement, Hinge: step 1, image 1 of 3 Samsung Chromebook Pro Hinge Replacement, Hinge: step 1, image 2 of 3 Samsung Chromebook Pro Hinge Replacement, Hinge: step 1, image 3 of 3
      • Remove the eight 30 mm screws from the edges of the case with the JIS J000 screw bit.
      Ask FixBot
    2. Samsung Chromebook Pro Hinge Replacement: step 2, image 1 of 3 Samsung Chromebook Pro Hinge Replacement: step 2, image 2 of 3 Samsung Chromebook Pro Hinge Replacement: step 2, image 3 of 3
      • Slide the plastic opening tool in a corner at a steep angle, and lift up to remove the outer case.
      Ask FixBot
    3. Samsung Chromebook Pro Hinge Replacement: step 3, image 1 of 3 Samsung Chromebook Pro Hinge Replacement: step 3, image 2 of 3 Samsung Chromebook Pro Hinge Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Locate the two white wires and one black wire. With the flat precision tweezers, untangle the white wires from the CONAN >PC+ABS< # 1-1.
      • Completely disconnect the black wire.
      Ask FixBot
    4. Samsung Chromebook Pro Hinge Replacement: step 4, image 1 of 3 Samsung Chromebook Pro Hinge Replacement: step 4, image 2 of 3 Samsung Chromebook Pro Hinge Replacement: step 4, image 3 of 3
      • Remove the three 30 mm screws using the JIS J000 screw bit from the black CONAN >PC+ABS< # 1-1 plate.
      • Once all the screws are removed from the CONAN >PC+ABS< # 1-1 plate, remove the wire attached to underside and lift the plate to remove.
      Ask FixBot
    5. Samsung Chromebook Pro Hinge Replacement: step 5, image 1 of 3 Samsung Chromebook Pro Hinge Replacement: step 5, image 2 of 3 Samsung Chromebook Pro Hinge Replacement: step 5, image 3 of 3
      • Locate hinge plates LP1 and RP1 on the top left and right corners of the Chromebook.
      • Remove the two 30 mm screws from hinge plates LP1 and RP1 using the JIS J000 screw bit.
      Ask FixBot
    6. Samsung Chromebook Pro Hinge Replacement: step 6, image 1 of 3 Samsung Chromebook Pro Hinge Replacement: step 6, image 2 of 3 Samsung Chromebook Pro Hinge Replacement: step 6, image 3 of 3
      • On the right top corner, locate the black and gold wire.
      • Lift the bar that is locking the wire in using the precision tweezers.
      • Disconnect the wire by grasping the black portion with the precision tweezers, and then pulling away from the Chromebook Pro.
      Ask FixBot
    7. Samsung Chromebook Pro Hinge Replacement: step 7, image 1 of 3 Samsung Chromebook Pro Hinge Replacement: step 7, image 2 of 3 Samsung Chromebook Pro Hinge Replacement: step 7, image 3 of 3
      • Completely open the Chromebook and gently separate both halves.
      • Be careful not to pull any wires.
      Ask FixBot
    8. Samsung Chromebook Pro Hinge Replacement: step 8, image 1 of 3 Samsung Chromebook Pro Hinge Replacement: step 8, image 2 of 3 Samsung Chromebook Pro Hinge Replacement: step 8, image 3 of 3
      • Make sure the Chromebook is facing up.
      • Place the plastic opening tool at an angle in the gap between the hinge and Chromebook screen and lift up.
      • Completely remove the plastic screen lining using the plastic opening tool.
      Ask FixBot
    9. Samsung Chromebook Pro Hinge Replacement: step 9, image 1 of 3 Samsung Chromebook Pro Hinge Replacement: step 9, image 2 of 3 Samsung Chromebook Pro Hinge Replacement: step 9, image 3 of 3
      • Remove the three 30 mm screws from hinge plate R1 and L1 using the JIS J000 screw bit.
      Ask FixBot
    10. Samsung Chromebook Pro Hinge Replacement: step 10, image 1 of 3 Samsung Chromebook Pro Hinge Replacement: step 10, image 2 of 3 Samsung Chromebook Pro Hinge Replacement: step 10, image 3 of 3
      • Disconnect the black wire on the R1 plate connected to the screen using the precision tweezers.
      Ask FixBot
    11. Samsung Chromebook Pro Hinge Replacement: step 11, image 1 of 3 Samsung Chromebook Pro Hinge Replacement: step 11, image 2 of 3 Samsung Chromebook Pro Hinge Replacement: step 11, image 3 of 3
      • Lift the hinge to remove from the Samsung Chromebook Pro.
      Ask FixBot
5 other people completed this guide.
6 Guide Comments
Great guide! One question: where can I buy the actual replacement hinge? Any tips?
Guy - Reply Share
I was able to find the hinges for mine on the Global Direct Parts web site. The item name is: OEM Samsung Chromebook Plus XE513C24, Pro XE510C24 Metal Hinge Set
Rob Riggle - Reply Share
How did you remove/unloop the cables in the hinges? do they just come right off?
Darby - Reply Share
The cables are just pushed into the side of the hinge. One side had a stopper holding the cable in place that I had to pull out, but the other had nothing holding the cable (that was the broken hinge on my chromebook, so maybe it had a stopper that had fallen out at one point). Once the stopper was removed from the one hinge, I could pull the cables out, and push them into new hinges.
Andrew Cullum - Reply Share
Just replaced these hinges on my computer … was only a bit confused with the stopper in the hinge but otherwise this guide was extremely helpful. Took about 30 min to do …
christophermdiaz - Reply Share
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 82
All Time: 9,713
