Samsung Chromebook Pro Battery Replacement
    1. Samsung Chromebook Pro Battery Replacement, Battery: step 1, image 1 of 2 Samsung Chromebook Pro Battery Replacement, Battery: step 1, image 2 of 2
      • Remove the eight 30 mm screws from the edges of the case with the JIS J000 screw bit.
      Ask FixBot
    2. Samsung Chromebook Pro Battery Replacement: step 2, image 1 of 3 Samsung Chromebook Pro Battery Replacement: step 2, image 2 of 3 Samsung Chromebook Pro Battery Replacement: step 2, image 3 of 3
      • Slide the plastic opening tool in a corner at a steep angle, and lift to remove the outer case.
      Ask FixBot
    3. Samsung Chromebook Pro Battery Replacement: step 3, image 1 of 2 Samsung Chromebook Pro Battery Replacement: step 3, image 2 of 2
      • Remove the four 30 mm screws surrounding the battery with the JIS J000 screw bit.
      Ask FixBot
    4. Samsung Chromebook Pro Battery Replacement: step 4, image 1 of 3 Samsung Chromebook Pro Battery Replacement: step 4, image 2 of 3 Samsung Chromebook Pro Battery Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Lift the connecting wires to disconnect from the slot with the precision tweezers.
      • Lift battery to remove once the wire is disconnected.
      Ask FixBot
4 other people completed this guide.
1 Guide Comment
How do I know which battery to order? Is there a specific part number?
Will - Reply Share
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 101
All Time: 3,544
