Samsung Chromebook Plus Battery Replacement
    1. Samsung Chromebook Plus Battery Replacement, Removing back panel screws: step 1, image 1 of 1
      • Remove the 8 PHILIPS#0 screws
      Ask FixBot
    2. Samsung Chromebook Plus Battery Replacement, Removing back panel: step 2, image 1 of 1
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Stick a plastic card (or fingernail) into the gap between panel and the body. Then lift the panel up (long side with speakers closest).
      Ask FixBot
    3. Samsung Chromebook Plus Battery Replacement, Removing battery screws: step 3, image 1 of 1
      • Use your PHILIPS#0 and remove the 4 screws
      Ask FixBot
    4. Samsung Chromebook Plus Battery Replacement, Removing the battery: step 4, image 1 of 1
      • Lift battery from bottom side first (marked with red line)
      Ask FixBot
    5. Samsung Chromebook Plus Battery Replacement, Finally detaching the battery: step 5, image 1 of 1
      • Detach battery cable grabbing the side and pulling the cable upward.
      Ask FixBot
    6. Samsung Chromebook Plus Battery Replacement, Inserting the new battery: step 6, image 1 of 1
      • Insert the battery and push the plug into the socket downward.
      Ask FixBot
    7. Samsung Chromebook Plus Battery Replacement, Re-inserting the screws: step 7, image 1 of 1
      • Re-insert the screws in the holes circled red (on this image), which is where you removed them previously.
      Ask FixBot
    8. Samsung Chromebook Plus Battery Replacement, The back panel gets re-inserted: step 8, image 1 of 1
      • Insert the hinge-side middle screw (must be done first otherwise casing may bulge) and insert rest of panel. On the hinge side, press down on the sides (if there is bulging) until you hear it snap. Insert the two other hinge-side screws (marked with orange on image). After that, insert the other 5 screws (yellow).
      Ask FixBot
To reassemble your device, skip steps 1-5.
7 other people completed this guide.
Evan Elm
1,041 Reputation
3 Guides authored
6 Guide Comments
Great repair guide. Nice to see how easy it is to replace battery.
N ick - Reply Share
Does anyone know where you can get a replacement battery?
Stanley Fujimoto - Reply Share
Sadly no, I have no idea, chromebookparts.com doesn't have a part either, haven't found one anywhere yet
Evan Elm - Reply Share
I managed to find a replacement part, see the parts section at the top of the guide :)
thanks for finding the battery part! Awesome job!
JT Cen - Reply Share
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 124
All Time: 8,151
