Samsung Chromebook 3 Battery Replacement
    1. Samsung Chromebook 3 Battery Replacement, Bottom Case: step 1, image 1 of 2 Samsung Chromebook 3 Battery Replacement, Bottom Case: step 1, image 2 of 2
      • Place the Chromebook face down so that the bottom case is exposed.
      • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
      Ask FixBot
    2. Samsung Chromebook 3 Battery Replacement: step 2, image 1 of 3 Samsung Chromebook 3 Battery Replacement: step 2, image 2 of 3 Samsung Chromebook 3 Battery Replacement: step 2, image 3 of 3
      • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
      • You should hear a popping sound as the connectors disengage inside the case.
      Ask FixBot
    3. Samsung Chromebook 3 Battery Replacement: step 3, image 1 of 1
      • Lift the case up and off the device
      Ask FixBot
    1. Samsung Chromebook 3 Battery Replacement, Battery: step 4, image 1 of 2 Samsung Chromebook 3 Battery Replacement, Battery: step 4, image 2 of 2
      • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
      Ask FixBot
    2. Samsung Chromebook 3 Battery Replacement: step 5, image 1 of 2 Samsung Chromebook 3 Battery Replacement: step 5, image 2 of 2
      • Use a spudger to gently pry the power cable cord upwards from the motherboard.
      Ask FixBot
    3. Samsung Chromebook 3 Battery Replacement: step 6, image 1 of 1
      • Lift the battery up and out from the case.
      Ask FixBot
5 other people completed this guide.
Austin Blakely
23,332 Reputation
53 Guides authored
1 Guide Comment
Can you fix my chromebook
Peter Hancocks - Reply Share
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 84
All Time: 2,502
