Samsung Chromebook 2 Trackpad Replacement
    1. Samsung Chromebook 2 Trackpad Replacement, Battery: step 1, image 1 of 1
      • Make sure your Chromebook is turned off before you begin.
      • Set the labtop face down on a flat surface.
      Ask FixBot
    2. Samsung Chromebook 2 Trackpad Replacement: step 2, image 1 of 3 Samsung Chromebook 2 Trackpad Replacement: step 2, image 2 of 3 Samsung Chromebook 2 Trackpad Replacement: step 2, image 3 of 3
      • Remove the nine 5 mm screws on the bottom cover using a Phillips #0 screwdriver.
      Ask FixBot
    3. Samsung Chromebook 2 Trackpad Replacement: step 3, image 1 of 2 Samsung Chromebook 2 Trackpad Replacement: step 3, image 2 of 2
      • Loosen the back cover panel with a plastic opening tool, and work it all the way around the computer.
      Ask FixBot
    4. Samsung Chromebook 2 Trackpad Replacement: step 4, image 1 of 2 Samsung Chromebook 2 Trackpad Replacement: step 4, image 2 of 2
      • Once the cover is loose, remove the back cover panel using your hands.
      Ask FixBot
    5. Samsung Chromebook 2 Trackpad Replacement: step 5, image 1 of 2 Samsung Chromebook 2 Trackpad Replacement: step 5, image 2 of 2
      • Unscrew the four 4 mm screws holding the battery in place with a Phillips #0 screwdriver.
      Ask FixBot
    6. Samsung Chromebook 2 Trackpad Replacement: step 6, image 1 of 3 Samsung Chromebook 2 Trackpad Replacement: step 6, image 2 of 3 Samsung Chromebook 2 Trackpad Replacement: step 6, image 3 of 3
      • Disconnect the wire that connects the battery to the motherboard by pulling upward.
      Ask FixBot
    1. Samsung Chromebook 2 Trackpad Replacement, Trackpad: step 7, image 1 of 3 Samsung Chromebook 2 Trackpad Replacement, Trackpad: step 7, image 2 of 3 Samsung Chromebook 2 Trackpad Replacement, Trackpad: step 7, image 3 of 3
      • Using the Phillips #00 screwdriver, remove the three 2 mm screws keeping the trackpad in place.
      Ask FixBot
    2. Samsung Chromebook 2 Trackpad Replacement: step 8, image 1 of 3 Samsung Chromebook 2 Trackpad Replacement: step 8, image 2 of 3 Samsung Chromebook 2 Trackpad Replacement: step 8, image 3 of 3
      • Remove the connector between the trackpad and the motherboard by pulling upwards on it at the port.
      Ask FixBot
    3. Samsung Chromebook 2 Trackpad Replacement: step 9, image 1 of 2 Samsung Chromebook 2 Trackpad Replacement: step 9, image 2 of 2
      Tool used on this step:
      Heavy-Duty Spudger
      Buy
      Ask FixBot
    4. Samsung Chromebook 2 Trackpad Replacement: step 10, image 1 of 2 Samsung Chromebook 2 Trackpad Replacement: step 10, image 2 of 2
      • Use a plastic opening tool to disconnect the metal trackpad support brackets.
      • Don't be afraid to use a moderate amount of force when prying the support brackets loose.
      Ask FixBot
    5. Samsung Chromebook 2 Trackpad Replacement: step 11, image 1 of 3 Samsung Chromebook 2 Trackpad Replacement: step 11, image 2 of 3 Samsung Chromebook 2 Trackpad Replacement: step 11, image 3 of 3
      • With the laptop slightly open, push the trackpad upwards at the rear, and pull it out from the bottom.
      Ask FixBot
7 other people completed this guide.
Sebastian Baba
436 Reputation
1 Guide authored
UW Tacoma, Team 1-3, Rose Winter 2016 Member of UW Tacoma, Team 1-3, Rose Winter 2016
UWT-ROSE-W16S1G3
4 Members
48 Guides authored
2 Guide Comments
Olá, gostei do site , pois apresenta um conteúdo bem rico em conhecimento gostaria de uma assistência sempre uso os métodos de reparo do site sempre da certo , porém não visualizei os manuais de reparo toubleshoting , ficaria muito agradecido caso vocês envie esses arquivos pra mim aprofundar meus conhecimentos da área de eletrônica .
atenciosamente.
jordson Martins Dantas - Reply Share
Reassembly Note: It should be noted that the trackpad will not "click" if the 2mm screws in STEP 7 are tight. Screw down until just snug then back off slightly. The bracket will then function correctly to return the trackpad to the up position after each click depress.
Nathan B. - Reply Share
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 118
All Time: 4,170
