Samsung Chromebook 2 Battery Replacement
    1. Samsung Chromebook 2 Battery Replacement, Battery: step 1, image 1 of 1
      • Make sure your Chromebook is turned off before you begin.
      • Set the labtop face down on a flat surface.
      Ask FixBot
    2. Samsung Chromebook 2 Battery Replacement: step 2, image 1 of 3 Samsung Chromebook 2 Battery Replacement: step 2, image 2 of 3 Samsung Chromebook 2 Battery Replacement: step 2, image 3 of 3
      • Remove the nine 5 mm screws on the bottom cover using a Phillips #0 screwdriver.
      Ask FixBot
    3. Samsung Chromebook 2 Battery Replacement: step 3, image 1 of 2 Samsung Chromebook 2 Battery Replacement: step 3, image 2 of 2
      • Loosen the back cover panel with a plastic opening tool, and work it all the way around the computer.
      Ask FixBot
    4. Samsung Chromebook 2 Battery Replacement: step 4, image 1 of 2 Samsung Chromebook 2 Battery Replacement: step 4, image 2 of 2
      • Once the cover is loose, remove the back cover panel using your hands.
      Ask FixBot
    5. Samsung Chromebook 2 Battery Replacement: step 5, image 1 of 2 Samsung Chromebook 2 Battery Replacement: step 5, image 2 of 2
      • Unscrew the four 4 mm screws holding the battery in place with a Phillips #0 screwdriver.
      Ask FixBot
    6. Samsung Chromebook 2 Battery Replacement: step 6, image 1 of 3 Samsung Chromebook 2 Battery Replacement: step 6, image 2 of 3 Samsung Chromebook 2 Battery Replacement: step 6, image 3 of 3
      • Disconnect the wire that connects the battery to the motherboard by pulling upward.
      Ask FixBot
3 other people completed this guide.
Allan
121 Reputation
1 Guide authored
UW Tacoma, Team 1-3, Rose Winter 2016 Member of UW Tacoma, Team 1-3, Rose Winter 2016
UWT-ROSE-W16S1G3
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 25
Past 30 Days: 114
All Time: 2,211
