Samsung Captivate Rear Case Replacement
    1. Samsung Captivate Rear Case Replacement, Battery: step 1, image 1 of 1
      • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
      • Lift up the back cover.
      Ask FixBot
    2. Samsung Captivate Rear Case Replacement: step 2, image 1 of 1
      • Place your finger on the bottom of the battery and lift to remove.
      Ask FixBot
    3. Samsung Captivate Rear Case Replacement: step 3, image 1 of 1
      • Replace the old battery with the new one.
      Ask FixBot
    1. Samsung Captivate Rear Case Replacement, Rear Case: step 4, image 1 of 1
      • Insert the spudger underneath the bottom section of the phone.
      • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
      Ask FixBot
    2. Samsung Captivate Rear Case Replacement: step 5, image 1 of 1
      • Remove the six 4.5mm #000 Phillips screws.
      Ask FixBot
    3. Samsung Captivate Rear Case Replacement: step 6, image 1 of 3 Samsung Captivate Rear Case Replacement: step 6, image 2 of 3 Samsung Captivate Rear Case Replacement: step 6, image 3 of 3
      • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
      • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
      • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
      Ask FixBot
    4. Samsung Captivate Rear Case Replacement: step 7, image 1 of 1
      • Separate the rear case from the phone.
      Ask FixBot
12 other people completed this guide.
Christopher
643 Reputation
4 Guides authored
Cal Poly, Team 20-25, Maness Fall 2011 Member of Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 45
All Time: 4,161
