Samsung Captivate Motherboard Replacement
    1. Samsung Captivate Motherboard Replacement, Battery: step 1, image 1 of 1
      • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
      • Lift up the back cover.
      Ask FixBot
    2. Samsung Captivate Motherboard Replacement: step 2, image 1 of 1
      • Place your finger on the bottom of the battery and lift to remove.
      Ask FixBot
    3. Samsung Captivate Motherboard Replacement: step 3, image 1 of 1
      • Replace the old battery with the new one.
      Ask FixBot
    1. Samsung Captivate Motherboard Replacement, Rear Case: step 4, image 1 of 1
      • Insert the spudger underneath the bottom section of the phone.
      • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
      Ask FixBot
    2. Samsung Captivate Motherboard Replacement: step 5, image 1 of 1
      • Remove the six 4.5mm #000 Phillips screws.
      Ask FixBot
    3. Samsung Captivate Motherboard Replacement: step 6, image 1 of 3 Samsung Captivate Motherboard Replacement: step 6, image 2 of 3 Samsung Captivate Motherboard Replacement: step 6, image 3 of 3
      • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
      • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
      • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
      Ask FixBot
    4. Samsung Captivate Motherboard Replacement: step 7, image 1 of 1
      • Separate the rear case from the phone.
      Ask FixBot
    1. Samsung Captivate Motherboard Replacement, Antenna Cable: step 8, image 1 of 2 Samsung Captivate Motherboard Replacement, Antenna Cable: step 8, image 2 of 2
      • Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
      • Pry up the other end of the cable from the connector on the antenna array.
      Ask FixBot
    1. Samsung Captivate Motherboard Replacement, Speaker: step 9, image 1 of 1
      • Use the Phillips 00 screwdriver to remove the single screw holding the speaker assembly to the LCD.
      Ask FixBot
    2. Samsung Captivate Motherboard Replacement: step 10, image 1 of 2 Samsung Captivate Motherboard Replacement: step 10, image 2 of 2
      • Use the plastic opening tool to lift the bottom tab of the plastic ribbon cable connector. Be careful not to use excessive force, you are only releasing the tab that holds the cable in.
      • Pull out the ribbon cable.
      • Use a spudger or plastic opening tool to lift up the speaker, and use your hands to remove it.
      Ask FixBot
    1. Samsung Captivate Motherboard Replacement, Camera Assembly: step 11, image 1 of 2 Samsung Captivate Motherboard Replacement, Camera Assembly: step 11, image 2 of 2
      • Lift up the black NEC chip with attached ribbon cable using either a spudger or plastic opening tool.
      • Gently lift the camera assembly out of the plastic housing.
      Ask FixBot
    1. Samsung Captivate Motherboard Replacement, Motherboard: step 12, image 1 of 3 Samsung Captivate Motherboard Replacement, Motherboard: step 12, image 2 of 3 Samsung Captivate Motherboard Replacement, Motherboard: step 12, image 3 of 3
      • Using the spudger slide the tool under the three highlighted connectors to begin disconnection
      • Excluding the motherboard socket, pry straight from up under the connectors, Therefore ending disconnection.
      • Be careful to not pry against the connector. Prying against could further damage to the device.
      Ask FixBot
    2. Samsung Captivate Motherboard Replacement: step 13, image 1 of 1
      • Use your fingers to carefully lift up the Samsung Capivate's Motherboard from the assembly.
      Ask FixBot
14 other people completed this guide.
Christopher
643 Reputation
4 Guides authored
Cal Poly, Team 20-25, Maness Fall 2011 Member of Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 Members
108 Guides authored
1 Guide Comment
hi, I have the captivate and I cannot get it to charge, i have had the charging port connection repaired in the past, but now I cannot get it to charge again
Mary B Chalfant - Reply Share
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 107
All Time: 14,370
