Samsung Captivate Glide Screen Replacement
    1. Samsung Captivate Glide Screen Replacement, Motherboard: step 1, image 1 of 3 Samsung Captivate Glide Screen Replacement, Motherboard: step 1, image 2 of 3 Samsung Captivate Glide Screen Replacement, Motherboard: step 1, image 3 of 3
      • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
      Ask FixBot
    2. Samsung Captivate Glide Screen Replacement: step 2, image 1 of 2 Samsung Captivate Glide Screen Replacement: step 2, image 2 of 2
      • Remove battery with plastic opening tool or finger.
      Ask FixBot
    3. Samsung Captivate Glide Screen Replacement: step 3, image 1 of 2 Samsung Captivate Glide Screen Replacement: step 3, image 2 of 2
      • Remove the seven screws from backplate using the #00 screwdriver.
      Ask FixBot
    4. Samsung Captivate Glide Screen Replacement: step 4, image 1 of 3 Samsung Captivate Glide Screen Replacement: step 4, image 2 of 3 Samsung Captivate Glide Screen Replacement: step 4, image 3 of 3
      • Remove the back plate using the plastic opening tool.
      • There is a lip on each side, and both must be pried up.
      • You can work your way around the edges after prying the two sides.
      Ask FixBot
    5. Samsung Captivate Glide Screen Replacement: step 5, image 1 of 2 Samsung Captivate Glide Screen Replacement: step 5, image 2 of 2
      • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
      Ask FixBot
    6. Samsung Captivate Glide Screen Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Disconnect the antenna cable from the motherboard using tweezers.
      Ask FixBot
    7. Samsung Captivate Glide Screen Replacement: step 7, image 1 of 1
      • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
      Ask FixBot
    8. Samsung Captivate Glide Screen Replacement: step 8, image 1 of 2 Samsung Captivate Glide Screen Replacement: step 8, image 2 of 2
      • Lift the motherboard out of the base of the phone.
      Ask FixBot
    1. Samsung Captivate Glide Screen Replacement, Screen: step 9, image 1 of 2 Samsung Captivate Glide Screen Replacement, Screen: step 9, image 2 of 2
      • Remove the eight screws with the #00 screwdriver.
      Ask FixBot
    2. Samsung Captivate Glide Screen Replacement: step 10, image 1 of 2 Samsung Captivate Glide Screen Replacement: step 10, image 2 of 2
      Buy
      Ask FixBot
    3. Samsung Captivate Glide Screen Replacement: step 11, image 1 of 1
      • Remove screws with the #00 screwdriver.
      Ask FixBot
    4. Samsung Captivate Glide Screen Replacement: step 12, image 1 of 1
      • Using the plastic opening tool, remove the back plate by prying on the four main points.
      • You may encounter difficultly at certain points. Work the plastic opening tool along the edge to keep back plate from closing again.
      Ask FixBot
    5. Samsung Captivate Glide Screen Replacement: step 13, image 1 of 1
      • Lift the back plate.
      • To remove to slide flex cable, gently peel back from the back plate and remove back plate.
      Ask FixBot
    6. Samsung Captivate Glide Screen Replacement: step 14, image 1 of 3 Samsung Captivate Glide Screen Replacement: step 14, image 2 of 3 Samsung Captivate Glide Screen Replacement: step 14, image 3 of 3
      • Slide the flex cable through the slot. Be careful to not tear the cable.
      • Set the front plate down.
      Ask FixBot
    7. Samsung Captivate Glide Screen Replacement: step 15, image 1 of 2 Samsung Captivate Glide Screen Replacement: step 15, image 2 of 2
      • Remove the four corner screws using the #00 screwdriver.
      Ask FixBot
    8. Samsung Captivate Glide Screen Replacement: step 16, image 1 of 3 Samsung Captivate Glide Screen Replacement: step 16, image 2 of 3 Samsung Captivate Glide Screen Replacement: step 16, image 3 of 3
      • Using the plastic opening tool, release all the clips on all four sides holding the screen assembly.
      • You can now remove the back plate by sliding the flex cable through the slot.
      Ask FixBot
    9. Samsung Captivate Glide Screen Replacement: step 17, image 1 of 3 Samsung Captivate Glide Screen Replacement: step 17, image 2 of 3 Samsung Captivate Glide Screen Replacement: step 17, image 3 of 3
      • Use the plastic opening tool to release the main jaw connector, front speaker and camera.
      Ask FixBot
    10. Samsung Captivate Glide Screen Replacement: step 18, image 1 of 2 Samsung Captivate Glide Screen Replacement: step 18, image 2 of 2
      • By using the plastic opening tool you can release the keypad flex cable from the jaw connecter clamp.
      Ask FixBot
    11. Samsung Captivate Glide Screen Replacement: step 19, image 1 of 2 Samsung Captivate Glide Screen Replacement: step 19, image 2 of 2
      • Use a heat gun or blow dryer.
      • Heat the outside edges using quick movements for about 45 seconds.
      Ask FixBot
    12. Samsung Captivate Glide Screen Replacement: step 20, image 1 of 3 Samsung Captivate Glide Screen Replacement: step 20, image 2 of 3 Samsung Captivate Glide Screen Replacement: step 20, image 3 of 3
      • Using the plastic opening tool to pry around the edges, release the touch screen from the screen frame.
      Ask FixBot
    13. Samsung Captivate Glide Screen Replacement: step 21, image 1 of 3 Samsung Captivate Glide Screen Replacement: step 21, image 2 of 3 Samsung Captivate Glide Screen Replacement: step 21, image 3 of 3
      • While adhesive is still warm, use the plastic opening tool to gently remove the keyboard flex cable from the screen.
      • You can now replace the screen assembly.
      Ask FixBot
2 other people completed this guide.
Tyler Moore
160 Reputation
1 Guide authored
USF Tampa, Team 5-3, Mcgee Fall 2014 Member of USF Tampa, Team 5-3, Mcgee Fall 2014
USFT-MCGEE-F14S5G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 121
All Time: 1,502
