Samsung Captivate Glide Camera Replacement
    1. Samsung Captivate Glide Camera Replacement, Motherboard: step 1, image 1 of 3 Samsung Captivate Glide Camera Replacement, Motherboard: step 1, image 2 of 3 Samsung Captivate Glide Camera Replacement, Motherboard: step 1, image 3 of 3
      • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
      Ask FixBot
    2. Samsung Captivate Glide Camera Replacement: step 2, image 1 of 2 Samsung Captivate Glide Camera Replacement: step 2, image 2 of 2
      • Remove battery with plastic opening tool or finger.
      Ask FixBot
    3. Samsung Captivate Glide Camera Replacement: step 3, image 1 of 2 Samsung Captivate Glide Camera Replacement: step 3, image 2 of 2
      • Remove the seven screws from backplate using the #00 screwdriver.
      Ask FixBot
    4. Samsung Captivate Glide Camera Replacement: step 4, image 1 of 3 Samsung Captivate Glide Camera Replacement: step 4, image 2 of 3 Samsung Captivate Glide Camera Replacement: step 4, image 3 of 3
      • Remove the back plate using the plastic opening tool.
      • There is a lip on each side, and both must be pried up.
      • You can work your way around the edges after prying the two sides.
      Ask FixBot
    5. Samsung Captivate Glide Camera Replacement: step 5, image 1 of 2 Samsung Captivate Glide Camera Replacement: step 5, image 2 of 2
      • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
      Ask FixBot
    6. Samsung Captivate Glide Camera Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Disconnect the antenna cable from the motherboard using tweezers.
      Ask FixBot
    7. Samsung Captivate Glide Camera Replacement: step 7, image 1 of 1
      • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
      Ask FixBot
    8. Samsung Captivate Glide Camera Replacement: step 8, image 1 of 2 Samsung Captivate Glide Camera Replacement: step 8, image 2 of 2
      • Lift the motherboard out of the base of the phone.
      Ask FixBot
    1. Samsung Captivate Glide Camera Replacement, Camera: step 9, image 1 of 3 Samsung Captivate Glide Camera Replacement, Camera: step 9, image 2 of 3 Samsung Captivate Glide Camera Replacement, Camera: step 9, image 3 of 3
      • Using the opening tool, pry up the camera attachment from the motherboard.
      Ask FixBot
Jessica Martinez
260 Reputation
2 Guides authored
USF Tampa, Team 5-3, Mcgee Fall 2014 Member of USF Tampa, Team 5-3, Mcgee Fall 2014
USFT-MCGEE-F14S5G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 28
Past 30 Days: 106
All Time: 1,232
