Samsung Captivate Earpiece Replacement
    1. Samsung Captivate Earpiece Replacement, Battery: step 1, image 1 of 1
      • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
      • Lift up the back cover.
      Ask FixBot
    2. Samsung Captivate Earpiece Replacement: step 2, image 1 of 1
      • Place your finger on the bottom of the battery and lift to remove.
      Ask FixBot
    3. Samsung Captivate Earpiece Replacement: step 3, image 1 of 1
      • Replace the old battery with the new one.
      Ask FixBot
    1. Samsung Captivate Earpiece Replacement, Rear Case: step 4, image 1 of 1
      • Insert the spudger underneath the bottom section of the phone.
      • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
      Ask FixBot
    2. Samsung Captivate Earpiece Replacement: step 5, image 1 of 1
      • Remove the six 4.5mm #000 Phillips screws.
      Ask FixBot
    3. Samsung Captivate Earpiece Replacement: step 6, image 1 of 3 Samsung Captivate Earpiece Replacement: step 6, image 2 of 3 Samsung Captivate Earpiece Replacement: step 6, image 3 of 3
      • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
      • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
      • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
      Ask FixBot
    4. Samsung Captivate Earpiece Replacement: step 7, image 1 of 1
      • Separate the rear case from the phone.
      Ask FixBot
    1. Samsung Captivate Earpiece Replacement, Antenna Cable: step 8, image 1 of 2 Samsung Captivate Earpiece Replacement, Antenna Cable: step 8, image 2 of 2
      • Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
      • Pry up the other end of the cable from the connector on the antenna array.
      Ask FixBot
    1. Samsung Captivate Earpiece Replacement, Camera Assembly: step 9, image 1 of 1
      • Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
      Ask FixBot
    2. Samsung Captivate Earpiece Replacement: step 10, image 1 of 1
      • Gently lift the camera assembly out of the plastic housing.
      Ask FixBot
    1. Samsung Captivate Earpiece Replacement, Motherboard: step 11, image 1 of 3 Samsung Captivate Earpiece Replacement, Motherboard: step 11, image 2 of 3 Samsung Captivate Earpiece Replacement, Motherboard: step 11, image 3 of 3
      • Using the spudger slide the tool under the three highlighted connectors to begin disconnection
      • Excluding the motherboard socket, pry straight from up under the connectors, Therefore ending disconnection.
      • Be careful to not pry against the connector. Prying against could further damage to the device.
      Ask FixBot
    2. Samsung Captivate Earpiece Replacement: step 12, image 1 of 1
      • Use your fingers to carefully lift up the Samsung Capivate's Motherboard from the assembly.
      Ask FixBot
    1. Samsung Captivate Earpiece Replacement, 3.5mm Headphone Jack: step 13, image 1 of 2 Samsung Captivate Earpiece Replacement, 3.5mm Headphone Jack: step 13, image 2 of 2
      • Gently pull up on the audio jack, taking the attached ribbon cable with it.
      • There is a small amount of glue holding the ribbon cable that attaches the audio jack to the earpiece.
      Ask FixBot
    1. Samsung Captivate Earpiece Replacement, Earpiece: step 14, image 1 of 1
      • The earpiece is attached to the 3.5mm audio jack. You will need to replace the entire assembly.
      Ask FixBot
2 other people completed this guide.
Drew Bentz
565 Reputation
5 Guides authored
Cal Poly, Team 20-25, Maness Fall 2011 Member of Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 30
Past 30 Days: 107
All Time: 2,961
