Up to 20% off select tools
Samsung Captivate Camera Assembly Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
104
All Time:
3,145
Comments: 2
2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Tools
  • Phillips #000 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
The camera assembly is susceptible to various environmental forces such as moisture, vibration, and shock. Replacing this part is easy.
    1. Samsung Captivate Camera Assembly Replacement, Battery: step 1, image 1 of 1
      • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
      • Lift up the back cover.
      Ask FixBot
    2. Samsung Captivate Camera Assembly Replacement: step 2, image 1 of 1
      • Place your finger on the bottom of the battery and lift to remove.
      Ask FixBot
    3. Samsung Captivate Camera Assembly Replacement: step 3, image 1 of 1
      • Replace the old battery with the new one.
      Ask FixBot
    1. Samsung Captivate Camera Assembly Replacement, Rear Case: step 4, image 1 of 1
      • Insert the spudger underneath the bottom section of the phone.
      • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
      Ask FixBot
    2. Samsung Captivate Camera Assembly Replacement: step 5, image 1 of 1
      • Remove the six 4.5mm #000 Phillips screws.
      Ask FixBot
    3. Samsung Captivate Camera Assembly Replacement: step 6, image 1 of 3 Samsung Captivate Camera Assembly Replacement: step 6, image 2 of 3 Samsung Captivate Camera Assembly Replacement: step 6, image 3 of 3
      • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
      • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
      • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
      Ask FixBot
    4. Samsung Captivate Camera Assembly Replacement: step 7, image 1 of 1
      • Separate the rear case from the phone.
      Ask FixBot
    1. Samsung Captivate Camera Assembly Replacement, Camera Assembly: step 8, image 1 of 1
      • Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
      Ask FixBot
    2. Samsung Captivate Camera Assembly Replacement: step 9, image 1 of 1
      • Gently lift the camera assembly out of the plastic housing.
      Ask FixBot
3 other people completed this guide.
Author
with
Drew Bentz
565 Reputation
5 Guides authored
Cal Poly, Team 20-25, Maness Fall 2011 Member of Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 Members
108 Guides authored
2 Guide Comments
Is this for the front facing camera
tracy mann - Reply Share
No, this is for the rear facing camera. The Samsung Captivate does not have a front facing camera.
Will Budney - Reply Share
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 104
All Time: 3,145
