Samsung Brightside Logic board Replacement
    1. Samsung Brightside Logic board Replacement, Logic board: step 1, image 1 of 3 Samsung Brightside Logic board Replacement, Logic board: step 1, image 2 of 3 Samsung Brightside Logic board Replacement, Logic board: step 1, image 3 of 3
      • Here is the Samsung SCH-U380 Brightside
      • Turn it over to gain access to the battery.
      • Remove the backcover by simply pulling it off the phone from the top down
      Ask FixBot
    2. Samsung Brightside Logic board Replacement: step 2, image 1 of 3 Samsung Brightside Logic board Replacement: step 2, image 2 of 3 Samsung Brightside Logic board Replacement: step 2, image 3 of 3
      • Remove the battery
      • Remove the six Phillips screws from the back frame
      • All six screws are identical M1.5X3
      Ask FixBot
    3. Samsung Brightside Logic board Replacement: step 3, image 1 of 3 Samsung Brightside Logic board Replacement: step 3, image 2 of 3 Samsung Brightside Logic board Replacement: step 3, image 3 of 3
      • Use a plastic opening tool or similar tool to separate the top from the bottom frame. Applying slight pressure in a downwards direction will disengage the plastic clips
      • Continue to slide the tool along the slot until you feel the plastic locks disengage
      • Once all locks have released, the bottom frame can simply be removed.
      Ask FixBot
    4. Samsung Brightside Logic board Replacement: step 4, image 1 of 3 Samsung Brightside Logic board Replacement: step 4, image 2 of 3 Samsung Brightside Logic board Replacement: step 4, image 3 of 3
      • Remove the two Phillips screws from the EMI shield.
      • Both screws are identical M1.5X2
      • Remove the EMI shield
      Ask FixBot
    5. Samsung Brightside Logic board Replacement: step 5, image 1 of 2 Samsung Brightside Logic board Replacement: step 5, image 2 of 2
      • Detach the LCD connector.
      • Remove the logic board
      Ask FixBot
3 other people completed this guide.
oldturkey03
859,453 Reputation
123 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 39
All Time: 2,185
