Samsung Blast Motherboard Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
26
All Time:
677
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 50 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
Use this guide to replace the motherboard of a Samsung Blast. This guide will take you through the process of how to successfully remove and replace the motherboard. A motherboard may need replacement if the device stops working.
Tools
    1. Samsung Blast Motherboard  Replacement, Motherboard: step 1, image 1 of 2 Samsung Blast Motherboard  Replacement, Motherboard: step 1, image 2 of 2
      • Remove the battery cover by pushing it upwards.
      Ask FixBot
    2. Samsung Blast Motherboard  Replacement: step 2, image 1 of 1
      • Take out the battery.
      Ask FixBot
    3. Samsung Blast Motherboard  Replacement: step 3, image 1 of 1
      • With a Phillips #00 screwdriver, remove the six screws that secure the back of the case.
      • You will not be able to completely remove the top two screws. Simply loosen them enough that you can still remove the cover.
      Ask FixBot
    4. Samsung Blast Motherboard  Replacement: step 4, image 1 of 1
      • Pull off the back cover of the phone.
      Ask FixBot
    5. Samsung Blast Motherboard  Replacement: step 5, image 1 of 2 Samsung Blast Motherboard  Replacement: step 5, image 2 of 2
      • Remove the volume and camera buttons by pulling them out.
      • Put the buttons aside until it is time to reassemble the phone.
      Ask FixBot
    6. Samsung Blast Motherboard  Replacement: step 6, image 1 of 1
      • Use the small plastic opening tool to gently remove the motherboard from the rest of the phone.
      Ask FixBot
    7. Samsung Blast Motherboard  Replacement: step 7, image 1 of 2 Samsung Blast Motherboard  Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Gently grab the motherboard with tweezers, then disconnect it from the two attached plates.
      Ask FixBot
Paige Weinstein
1 Reputation
1 Guide authored
Ohio State, Team 1-5, Buehl Spring 2014 Member of Ohio State, Team 1-5, Buehl Spring 2014
OSU-BUEHL-S14S1G5
4 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 26
All Time: 677
