Up to 20% off select tools
Samsung Blast Keyboard Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
18
All Time:
762
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Parts
Tools
    1. Samsung Blast Keyboard Replacement, At a Glance: step 1, image 1 of 2 Samsung Blast Keyboard Replacement, At a Glance: step 1, image 2 of 2
      • Your phone should look like this before disassembly.
      Ask FixBot
    2. Samsung Blast Keyboard Replacement, Battery Case Removal: step 2, image 1 of 2 Samsung Blast Keyboard Replacement, Battery Case Removal: step 2, image 2 of 2
      • Remove the battery cover by sliding the back panel up. This will expose the battery.
      Ask FixBot
    3. Samsung Blast Keyboard Replacement, Remove Battery/Sim card: step 3, image 1 of 1
      • Lift up the top portion of the battery and pull it out.
      • Next, slide the sim card out of its socket and set it aside.
      Ask FixBot
    4. Samsung Blast Keyboard Replacement, Back Case Removal: step 4, image 1 of 2 Samsung Blast Keyboard Replacement, Back Case Removal: step 4, image 2 of 2
      • Use a Phillips #00 Screwdriver to unscrew the six small screws that secure the back of the case.
      • The top two screws are connected to the back cover. They will not come off once unscrewed.
      • Remove the case by prying around the edges.
      • Note the positions of button pads for reassembly.
      Ask FixBot
    5. Samsung Blast Keyboard Replacement, Button Pads: step 5, image 1 of 2 Samsung Blast Keyboard Replacement, Button Pads: step 5, image 2 of 2
      • Remove the buttons for the camera and volume.
      Ask FixBot
    6. Samsung Blast Keyboard Replacement, Motherboard Removal: step 6, image 1 of 3 Samsung Blast Keyboard Replacement, Motherboard Removal: step 6, image 2 of 3 Samsung Blast Keyboard Replacement, Motherboard Removal: step 6, image 3 of 3
      • Use a prying tool to detach the motherboard from main body.
      • Carefully detach the motherboard from the two connectors.
      • You could also use a pry tool for the second step.
      • Be careful with the motherboard as not to scrape or damage its components.
      Ask FixBot
    7. Samsung Blast Keyboard Replacement, Keyboard Pad Replacement: step 7, image 1 of 2 Samsung Blast Keyboard Replacement, Keyboard Pad Replacement: step 7, image 2 of 2
      • Slide the keyboard straight up to free it from its alignment pins.
      • Swap the broken keyboard with a replacement here, and follow the repair steps in reverse order for reassembly.
      Ask FixBot
Author
with
Jordan Taylor
10 Reputation
1 Guide authored
Ohio State, Team 1-5, Buehl Spring 2014 Member of Ohio State, Team 1-5, Buehl Spring 2014
OSU-BUEHL-S14S1G5
4 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 762
