Up to 20% off select tools
Samsung Blackjack Back Phone Casing Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
24
All Time:
991
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Use this guide to replace the back phone case and to remove the casing to access the inside of the phone.
    1. Samsung Blackjack Back Phone Casing Replacement, Battery Cover: step 1, image 1 of 3 Samsung Blackjack Back Phone Casing Replacement, Battery Cover: step 1, image 2 of 3 Samsung Blackjack Back Phone Casing Replacement, Battery Cover: step 1, image 3 of 3
      • Hold the device with the screen facing away from you and the camera towards you.
      • Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
      Ask FixBot
    1. Samsung Blackjack Back Phone Casing Replacement, Battery: step 2, image 1 of 2 Samsung Blackjack Back Phone Casing Replacement, Battery: step 2, image 2 of 2
      • Place your fingers on both sides of the bottom of the battery and lift upwards.
      • Pull the battery away from the phone.
      Ask FixBot
    1. Samsung Blackjack Back Phone Casing Replacement, SIM Card: step 3, image 1 of 3 Samsung Blackjack Back Phone Casing Replacement, SIM Card: step 3, image 2 of 3 Samsung Blackjack Back Phone Casing Replacement, SIM Card: step 3, image 3 of 3
      • Place your thumb on the SIM card.
      • Slide the card out of the slot.
      Ask FixBot
    1. Samsung Blackjack Back Phone Casing Replacement, Back Phone Casing: step 4, image 1 of 2 Samsung Blackjack Back Phone Casing Replacement, Back Phone Casing: step 4, image 2 of 2
      • Use the spudger to remove the rubber stoppers from the top of the cover.
      • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
      Ask FixBot
    2. Samsung Blackjack Back Phone Casing Replacement: step 5, image 1 of 3 Samsung Blackjack Back Phone Casing Replacement: step 5, image 2 of 3 Samsung Blackjack Back Phone Casing Replacement: step 5, image 3 of 3
      • Use the spudger to loosen and separate the front and back covers.
      • Pick up the back cover once loosened.
      • The front and back covers will be attached to each other by a gold wire.
      • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
      Ask FixBot
Author
with
Kristin Manna
29 Reputation
10 Guides authored
Clemson, Team 14-4, Benson Fall 2012 Member of Clemson, Team 14-4, Benson Fall 2012
CLEM-BENSON-F12S14G4
3 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 24
All Time: 991
