Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Spudger4.9
Introduction
Go to step 1 ↓Use this guide to install, remove, or replace the phone's keypad.
Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone.
Tool used on this step:Tweezers$4.99
Use the spudger to pry the two plastic caps out of the top corners of the phone casing.
Pry apart the plastic tabs along the edges of the phone.
Separate the front panel from the main body of the phone using your fingers.
