Introduction
Use this guide to install, remove or replace the phone's audio receiver.
Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone.
Tool used on this step:Tweezers$4.99
Use the spudger to pry the two plastic caps out of the top corners of the phone casing.
Pry apart the plastic tabs along the edges of the phone.
Separate the front panel from the main body of the phone using your fingers.
The audio receiver is a small rectangular piece connected via wire to the circuit board.
Carefully free the audio receiver so it is only connected by a small, clear plug on the circuit board.
