Samsung BD-JM57C Wi-Fi Card Replacement
  1. Samsung BD-JM57C Wi-Fi Card Replacement, Top Cover: step 1, image 1 of 2 Samsung BD-JM57C Wi-Fi Card Replacement, Top Cover: step 1, image 2 of 2
    • Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
    • Remove the cover by sliding it up and then out.
    Ask FixBot
  2. Samsung BD-JM57C Wi-Fi Card Replacement, Disc Drive: step 2, image 1 of 2 Samsung BD-JM57C Wi-Fi Card Replacement, Disc Drive: step 2, image 2 of 2
    • Disconnect the two ribbons that connect the disc drive to the motherboard.
    Ask FixBot
  3. Samsung BD-JM57C Wi-Fi Card Replacement: step 3, image 1 of 2 Samsung BD-JM57C Wi-Fi Card Replacement: step 3, image 2 of 2
    • Push in on the two metal tabs on the side of the disc drive.
    • Push forward to slide the disc drive out of the casing.
    Ask FixBot
  4. Samsung BD-JM57C Wi-Fi Card Replacement, WiFi Card: step 4, image 1 of 2 Samsung BD-JM57C Wi-Fi Card Replacement, WiFi Card: step 4, image 2 of 2
    • Pull clip to remove the WiFi card ribbon connected to the circuit board.
    • Push the black plastic tab out and slide the WiFi card out from the cage.
    Ask FixBot
1 Guide Comment
, please I don’t know if you can help me repair my Samsung bd blu ray player, it keeps showing wired connection and don’t let me connect on wireless, I will pay please
Latoya Jerry - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 29
All Time: 523
