Up to 20% off select tools
Samsung BD-JM57C Open Button Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
73
All Time:
2,053
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 minutes - 1 hour
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace a broken or faulty open button on your Samsung BD-JM57C Blu ray player.
The open button on the Blu-ray player allows all the disc tray to open and close, allowing you to insert a DVD or Blu-ray disc. A broken or faulty open button will prohibit the disc tray from operating.
Before taking apart the Blu-ray player and replacing the open button, look at the troubleshooting page for the Samsung BD-JM57C and see if your problem can be resolved.
Make sure the device is not plugged in before working on it.
Soldering is a requirement to complete this guide. Use the How to Solder and Desolder Connections guide for more information on soldering.
    1. Samsung BD-JM57C Open Button Replacement, Top Cover: step 1, image 1 of 2 Samsung BD-JM57C Open Button Replacement, Top Cover: step 1, image 2 of 2
      • Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
      • Remove the cover by sliding it up and then out.
      Ask FixBot
    1. Samsung BD-JM57C Open Button Replacement, Disc Drive: step 2, image 1 of 2 Samsung BD-JM57C Open Button Replacement, Disc Drive: step 2, image 2 of 2
      • Disconnect the two ribbons that connect the disc drive to the motherboard.
      Ask FixBot
    2. Samsung BD-JM57C Open Button Replacement: step 3, image 1 of 2 Samsung BD-JM57C Open Button Replacement: step 3, image 2 of 2
      • Push in on the two metal tabs on the side of the disc drive.
      • Push forward to slide the disc drive out of the casing.
      Ask FixBot
    1. Samsung BD-JM57C Open Button Replacement, WiFi Card: step 4, image 1 of 2 Samsung BD-JM57C Open Button Replacement, WiFi Card: step 4, image 2 of 2
      • Pull clip to remove the WiFi card ribbon connected to the circuit board.
      • Push the black plastic tab out and slide the WiFi card out from the cage.
      Ask FixBot
    1. Samsung BD-JM57C Open Button Replacement, Power Cord: step 5, image 1 of 2 Samsung BD-JM57C Open Button Replacement, Power Cord: step 5, image 2 of 2
      • Use the Phillips #00 Screwdriver to remove the two 6.4 mm screws holding the cage in place.
      • Lift the cage up to remove it.
      Ask FixBot
    2. Samsung BD-JM57C Open Button Replacement: step 6, image 1 of 1
      • Push in the small white lever and pull it towards you to release the cord.
      Ask FixBot
    3. Samsung BD-JM57C Open Button Replacement: step 7, image 1 of 1
      • Move the power cord out from under the metal tab on the side of the case.
      Ask FixBot
    4. Samsung BD-JM57C Open Button Replacement: step 8, image 1 of 1
      • Remove the rubber spacer on the edge of the case holding the cord in place.
      • Remove the power cord from the device.
      Ask FixBot
    1. Samsung BD-JM57C Open Button Replacement, Motherboard: step 9, image 1 of 1
      • After the power cord has been disconnected, remove the yellow circuit board from the Blu ray player.
      • There is nothing holding down the circuit board, do not forcefully remove it or try to remove other parts from it.
      Ask FixBot
    2. Samsung BD-JM57C Open Button Replacement: step 10, image 1 of 1
      • Use the Phillips #00 screwdriver to remove the 9.7mm screw holding the HDMI port in place on the outside of the case.
      Ask FixBot
    3. Samsung BD-JM57C Open Button Replacement: step 11, image 1 of 1
      • Use the Phillips #00 screwdriver to remove the 6.4mm screw holding the motherboard in place.
      • Pull the motherboard up to remove it from the device.
      Ask FixBot
    1. Samsung BD-JM57C Open Button Replacement, Open Button: step 12, image 1 of 1
      • Locate the Open Button on the circuit board.
      Ask FixBot
    2. Samsung BD-JM57C Open Button Replacement: step 13, image 1 of 1
      • Flip the motherboard over so that the green side is facing you.
      • Use a soldering iron to desolder the two points to disconnect the open button.
      • For more information on soldering, please read the How To Solder and Desolder Connections guide.
      Ask FixBot
2 other people completed this guide.
Author
with
Abby Hudson
646 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 73
All Time: 2,053
