Samsung BD-JM57C Motherboard Replacement
  1. Samsung BD-JM57C Motherboard Replacement, Top Cover: step 1, image 1 of 2 Samsung BD-JM57C Motherboard Replacement, Top Cover: step 1, image 2 of 2
    • Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
    • Remove the cover by sliding it up and then out.
    Ask FixBot
  2. Samsung BD-JM57C Motherboard Replacement, Disc Drive: step 2, image 1 of 2 Samsung BD-JM57C Motherboard Replacement, Disc Drive: step 2, image 2 of 2
    • Disconnect the two ribbons that connect the disc drive to the motherboard.
    Ask FixBot
  3. Samsung BD-JM57C Motherboard Replacement: step 3, image 1 of 2 Samsung BD-JM57C Motherboard Replacement: step 3, image 2 of 2
    • Push in on the two metal tabs on the side of the disc drive.
    • Push forward to slide the disc drive out of the casing.
    Ask FixBot
  4. Samsung BD-JM57C Motherboard Replacement, Power Cord: step 4, image 1 of 2 Samsung BD-JM57C Motherboard Replacement, Power Cord: step 4, image 2 of 2
    • Use the Phillips #00 Screwdriver to remove the two 6.4 mm screws holding the cage in place.
    • Lift the cage up to remove it.
    Ask FixBot
  5. Samsung BD-JM57C Motherboard Replacement: step 5, image 1 of 1
    • Push in the small white lever and pull it towards you to release the cord.
    Ask FixBot
  6. Samsung BD-JM57C Motherboard Replacement: step 6, image 1 of 1
    • Move the power cord out from under the metal tab on the side of the case.
    Ask FixBot
  7. Samsung BD-JM57C Motherboard Replacement: step 7, image 1 of 1
    • Remove the rubber spacer on the edge of the case holding the cord in place.
    • Remove the power cord from the device.
    Ask FixBot
  8. Samsung BD-JM57C Motherboard Replacement, Motherboard: step 8, image 1 of 1
    • After the power cord has been disconnected, remove the yellow circuit board from the Blu ray player.
    • There is nothing holding down the circuit board, do not forcefully remove it or try to remove other parts from it.
    Ask FixBot
  9. Samsung BD-JM57C Motherboard Replacement: step 9, image 1 of 1
    • Use the Phillips #00 screwdriver to remove the 9.7mm screw holding the HDMI port in place on the outside of the case.
    Ask FixBot
  10. Samsung BD-JM57C Motherboard Replacement: step 10, image 1 of 1
    • Use the Phillips #00 screwdriver to remove the 6.4mm screw holding the motherboard in place.
    • Pull the motherboard up to remove it from the device.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 44
All Time: 948
