Samsung BD-F5900 Main Logic Board Replacement
  1. Samsung BD-F5900 Main Logic Board Replacement, Top Cover: step 1, image 1 of 1
    • Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
    • Tilt the back of the top cover forward to remove from chassis.
    Ask FixBot
  2. Samsung BD-F5900 Main Logic Board Replacement: step 2, image 1 of 1
    • Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
    Ask FixBot
  3. Samsung BD-F5900 Main Logic Board Replacement, Power Supply: step 3, image 1 of 2 Samsung BD-F5900 Main Logic Board Replacement, Power Supply: step 3, image 2 of 2
    • Using a #1 Phillips head screwdriver, remove the two 7.5mm screws on top of the plastic cover and remove the cover.
    Ask FixBot
  4. Samsung BD-F5900 Main Logic Board Replacement: step 4, image 1 of 1
    • Press down on the plastic retaining clip and pull backwards to remove the AC power connector from the power supply board.
    Ask FixBot
  5. Samsung BD-F5900 Main Logic Board Replacement: step 5, image 1 of 3 Samsung BD-F5900 Main Logic Board Replacement: step 5, image 2 of 3 Samsung BD-F5900 Main Logic Board Replacement: step 5, image 3 of 3
    • Using the plastic spudger tool, gently pry on either side of main power connector (CON801) to disconnect from main logic board.
    • Pry a little bit on each side of board until the board lifts away.
    • Tilt the board forward and lift up to remove from the chassis.
    Ask FixBot
  6. Samsung BD-F5900 Main Logic Board Replacement, Main Logic Board: step 6, image 1 of 1
    • Remove the two ribbon cables from the Main Logic Board assembly by gently pulling up on the blue tab.
    • Be careful not to damage the ribbon cable by using too much force.
    Ask FixBot
  7. Samsung BD-F5900 Main Logic Board Replacement: step 7, image 1 of 1
    • Disconnect the WiFi board cable connector
    Ask FixBot
  8. Samsung BD-F5900 Main Logic Board Replacement: step 8, image 1 of 2 Samsung BD-F5900 Main Logic Board Replacement: step 8, image 2 of 2
    • Using a #1 Phillips head screwdriver, remove the three 7.5 mm screws from the board
    • Also remove the 10 mm screw from the rear panel.
    • Remove the Main Logic Board
    Ask FixBot
Louis McKean
528 Reputation
5 Guides authored
USF Tampa, Team S1-G21, Cagle Fall 2017 Member of USF Tampa, Team S1-G21, Cagle Fall 2017
USFT-CAGLE-F17S1G21
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 22
All Time: 747
